Can somone tell me
Can somone tell me
Can somone tell me
david
>how Watco Danish Oil is regarding spontaneous combustion? I know you are supposed to be carefull of oily rags and such, but I use paper towels to wipe off items soaked in Watco, and it would help if I knew if the soaked items are highly combustible, mildly combustible, or not very combustible. Hope you chemical experts out there can help me. TIA.
David
Kaneohe, HI
the windward side of Oahu
Re: Can somone tell me
Kirk (KC) Constable
>You won't go wrong by assuming they're highly combustible, and treating them accordingly. When in doubt....
KC
>I agree with Kirk. I could never remember which is which anyway so anytime I use and oily soaked anything I lay it in the middle of the shop floor (which is concrete) to dry. When a rag is spread out it can't build up the heat. I just make sure it's at least 3 feet from anything and not sitting in a pile of shavings.
Steve in NC
>I think Watco is on the danger list and I do not think it makes a difference paper towel vs rags. I agree with John, play it safe.
I use a safety can designed for this purpose. It has a spring loaded lid and is designed to cut off oxygen and contain any fires. I use if for any rag (or towel) with any kind of finish or lubricant on it. It was easy peace of mind.
House fire
Terry Quiram, Roanoke Illinois
>Years ago we did a lot of crafting (scroll work)and finished entirely with Watco. We had a house fire because of spontaneous combustion by oily rags left in a pile. Lucky the fire was limited to one room but the entire house suffered smoke damage. Now all finishing is done in my shop and the rags are immediately removed to a metal trash can away from the building.
Treat those rags with the utmost respect.
Terry
ebd
ebd
>The critical phrase is "left in a pile". That's the only way that enough heat can be generated to spontaneously combust. And it takes a large mass of oily/solvent soaked rags kept somewhere without ventilation. Small rags/paper used to apply Watco usually dry beyond the "combustable without an external ignition source" very quickly. Just allow them to dry and make sure you don't accumulate a mass of soaked material that's in a place where it's going to stay wet. I try to keep my applicators wet in a closed container so I can reuse them. Even there Watco often hardens before I get back to use the rag again.
Bill Howatt
>I think anything that is a "drying oil" or contains linseed oil is a definite problem but since this is a "think" rather than "know", I treat all oily rags the same.
If I lay one down I always spread it out.
If I am finished with it, I put it in a large coffee can with lid that is 1/2-3/4 filled with water. This coffee can is stored inside an old metal shop-vac cannister with lid.
Don't do what some guy did a few years ago, threw them out his back door - landed on his deck, combusted and set the house on fire.
Bill
What about oil soaked shavings?
Stuart Johnson
>I was sanding on the lathe using Watco Danish Oil and realized it was really dripping on a pile of shavings. I got to worrying about them and clean them up and dumped them in my burn pile. Would these have been the same as oil soaked rags?
Re: What about oil soaked shavings?
Bill Howatt
>I'm going to say yes, but I'm not an expert. The reason I say yes is that the issue is heat generated when the oil dries and if the heat is contained such as under a pile of shavings then the temperature can get very hot and ignite the shavings. Naturally, some materials will catch fire easier than others. This same phenomenen happens in silos when wet organic material is stored in silo. As it decays heat is produced which can then set the material on fire.
Bill
Bill Crommett
>I do like John does, except I put the rags and paper towels out on the concrete driveway.
Don't use it!
georgetroy
Thanks all, for the sage advice...
david
