Slicing bologna.
Slicing bologna.
Slicing bologna.
Gary Evans Tallassee, TN
>Hi all,
Years ago, my grandfather ran a grocery store and I can still remember him being able to make 1/2" slices of bologna and other sandwich meats on his big slicer.
I need to make 1/2" or 3/4" slices from a 4" round to use as washers to hang my new parachute. It's the cheapest ceiling material I could find for a 1600 sqft space and I think that 4" washers will provide sufficient support for the material.
I'm trying to figure out whether it would be more efficient to use a parting tool to cut the slices, or to slice them off with the bandsaw. The negative side of the parting tool is that it's a pretty good stretch off the toolrest to get to the middle of that blank.
The negative side of using the bandsaw is that I would really like to decorate the surface of each disc with some grooves or beads, or something. Having to pull the blank off the lathe for every cut would take some time. I figure I'm going to need 20 or so.
So, what I'm looking for are 4" by 3/4" discs with a decorated surface. Any suggestions would be appreciated.
Gary
Re: Slicing bologna.
>My friend Randy makes the weights for some chimes for another artist. They are just about that size. Randy uses 3/4" wood and cuts squares. Then center drills with a forestner bit. He expands a chuck into this and turns the outside and one side with a recess for the chuck. Then turns it around and turns the other side. It goes really quick.
Ruth Niles
>I like John's friend's method, sounds quick, easy and each would be the same size.
Gary, forget the parting tool, remember by stuck face plate? yep, parting tool did it!
>For deep cuts like these I use a homemade heavy duty thin parting tool. It's made from an industrial bandsaw blade and is fairly wide (tall). This supports the cut so it doesn't flex. It cuts about 1/8" or less so there is less cutting pressure needed. I always make two cuts pulling the blade out and then pushing back in, several times until I cut through. This blade takes less pressure than a full size parting tool.
I think a diamond parting tool used with the bevel rubbing doesn't apply much force against the wood either. I've never had a faceplate lock up due to parting but it could just be my luck or my lathes or both. Maybe Ruth was using an English Tool on a Canadian lathe and they disagreed. :)
tek-Brunswick, Ohio
>Turn the lathe speed down low and use a hacksaw to cut off the slices. One of the National demonstrators showed our club that. I can't remember which demonstrator though. My guess is it was Alan Lacer. I find it easier to start the cut in a groove made by a parting tool or a v from a skew. You don't have to saw back and forth just hold it steady and follow it through the piece. You get less tear out than you do with a parting tool. Use a blades with fewer teeth per inch cut faster.
another way...not necessarily better....
TDaniel
>Gary, you could turn a cylinder, then bore it with a Forster bit to some diameter; then part the sections. Ater doing this you could turn another cylinder to fit the hole drilled by the Forster and part off "plugs" to fit the i.d. of the first pieces. You could use contrasting woods for an effect or you could go as far as cutting designs on the sides (ends) of either piece or you could use a chatter tool. You might even cut the inner piece a little short and create another dimension. There are many ways to skin a cat.
>I like that idea, John, but I need these to have a closed center with just enough hole for a screw to go through so that I can screw them to a ceiling joist. Plus, I'd be limited to either walnut, ash or cherry since those are the only woods I have in board form at the moment, and I'm not positive that I have any 4" cherry.
If I make them from cylinders then I could make each one from a different wood, which is one thing I was thinking about doing to add a little visual interest to the ceiling.
On the other hand, a 64' diameter camo parachute has a lot of visual interest going on anyway, so a wide variety of woods probably won't matter.
Gary
>Hi Ruth,
I wasn't feeling too comfortable with the parting tool thing. That would be farther than I ever cut with one before.
Did you ever figure out what the noise was on your General? I don't think I ever read the outcome of your adventure.
Gary
>Thanks tek,
That sounds like a good way to do it. I wasn't looking forward to pulling the cylinder off the lathe to cut each slice. Plus I would have to cobble together some kind of V-jig to hold the cylinder for cutting on the bandsaw.
I'll definitely try this one.
Gary
Re: another way...not necessarily better....
>Hi Terry,
That would be a good way to add some more interest to these pieces. Unfortunately, I have so many things to do to get this space ready, I'm trying to find ways to do each task as quickly as possible. I might save that method and make some new and improved "washers" when I don't have anything else to do.
Thanks,
Gary
Walt Ahlgrim
>So you need about 200 of the washers? I would start with firewood cut it into slices on the band saw 3/8 of an inch thick than length of your screw chuck. Drill a hole in each for a screw chuck. Put a slice on the lathe flatten one side make it round. Remove it from the screw put the flat side on the chuck true it up, decorate this side and start on the next.
This would work if you can get by with a 3/8 center hole and a 6 inch diameter washer.
Wilford Bickel
>I would part them off - If you want to use something like a chatter tool glue a rounded 4 inch + diameter piece to a scrap piece of wood on a faceplate,true up to 4 inches, chatter the end and then part off. A 4 inch diameter means you only have to part off 2 inches deep - I do that all the time making boxes and find no problem with the distance off the tool rest. You could do the same using the Sorby texturing tool
Walt Ahlgrim
>PS Will the fire marshal to approve this ceiling? A few years ago someone covered there ceiling with cheep foam because someone complained about the noise from the bands. People died in a fire and other are in jail for few bucks. Please think about safety.
Walt A
Wagner Safety Plane
Curly Smith
>Another idea -- use a Wagner Safety Plane or a drill press plane (Woodcraft sells them). Cut your disks on the bandsaw using a v-jig then take them to your drill press and make rosettes with the Safety Plane. It's simple, and they're decorated in no time after you've made the initial simple jig. The plane costs around $50.
Want different shapes? Make different jigs.
Fire
Wilford Bickel
>Parachutes are normally made from nylon. Nylon fabric passes most flame tests as it melts and goes out rather than keeps on burning as cotton fabric or the foam you mention will support a flame and keep burning. The fire marshal may want a flame test performed or he may be able to pass it based on the nylon it contains.
>Gary The V jig for the bandsaw only takes a few minutes to make and works really well.
>Gary If I remember correctly you don't have a vacuum chuck yet. That is the way I would do it. Turn cylinders, cut slices on the bandsaw. Put the slices on the vacuum chuck and turn one side. Flip them over and turn the other side, then drill your hole as the last thing. Other than that I would use my 4" jaws on my vicmarc chuck to grap the outside of the discs and then turn the face of each one.
Re: Slicing bologna. *LINK*
John U - Charlotte, NC
>Gary -- If you want face grain washers vs. endgrain washers, consider bandsawing boards from the variety of wood you want to use. Or use your existing lumber. Bandsaw the boards into squares or rough circles, and drill a pilot hole through the center, then use a MT screw center to drive the washer blank. True up the outside and face, and decorate as needed. Turn it around, true up the back face or turn a slight hollow (since that side will be against the ceiling). The center hole should be close to the size you need for ceiling mounting.
Sears offers a cheap screw center that you may luck in and find at a store, but also online:
Craftsman Screw Center, Morse Taper No. 2
Sears item #00929846000 Mfr. model #29846
Another option after rough sawing the boards is to use a waste block in a chuck. Drill a center pilot hole in the waste block, and screw your board blank directly to the waste block through a single center hole. To help slipping, maybe face the waste block with sandpaper or double sided tape.
Sears Screw Center
eaglesc
>I realize this is a turning forum but I would think the obvious way to cut these "washers" would be on a bandsaw with a hole saw.
HF has them on sale often and will cut 1" stock.
the "decorations"
could be the smaller hole saws not cut all the way through.
after all the "grooves" are cut you would cut the "doughnut out of the flat stock.
Of course that's just the way I would do it.
Michael Wilkins
>Leave the 4" round on the lathe while you cut the grooves into the end. Then go to the bandsaw and cut your slices off.
Go back to the lathe, true up the face, cut more grooves, back to the bandsaw. Continue this dance until you have enough discs.
eaglesc
>Excuse my original typo not enough coffee.
I realize this is a turning forum but I would think the obvious way to cut these "washers" would be on a DRILL PRESS with a hole saw.
The "decorations" could be the smaller hole saws not cut all the way through.
after all the "grooves" are cut you would cut the "doughnut" out of the flat stock.
Re: Wouldn't duck tape be easier??
Russ Fairfield
Why not buy some shower rings?
Ron in Drums PA
>Fortunately, Walt, I only need about 20.
I guess since I have so many different things that have to be done before I open for business, I'm trying to find the very fastest way to do each of them.
I thought about using end-grain discs, but I think I'll stay with side-grain. Otherwise, your method would be a good one.
Thanks for the input,
Gary
>After reading your post, Wilford, it seems that a parting tool might not be a bad way to do it. I've been looking for an excuse to make a thin-blade one. I've got the blade stock. I just need to make a handle. Maybe I'll go ahead and do it for this project.
Thanks,
Gary
