outboard turning- long
Dale Cook
>Here's a picture of the outboard turning toolrest and tailstock holder. It's only clamped on right now but it is held on by bolting a piece of 1/2 by 6 inch plate steel to the end of the lathe which is welded to the top of a 3 inch square steel tube in which a 2 and 1/2 inch steel tube can slide in or out. The vertical is a floor plate welded to a 3 inch square tube and a 2 and 1/2 tube inside for up and down adjustments. The bed is 4 inch C-channel steel with 1/2 by 1 and 1/2 welded on each side. The banjo and tailstock fit right on here so I can use the tailstock for extra support. I plan on bolting this on shortly and could use sandbags for extra weight, I've used this just clamped on and it worked very nicely.I welded a nut on the 3 inch tubes so a bolt goes through to the inner tube. Still have to paint.
Re: outboard turning- long
Allen Neighbors
>Dale, I'm not trying to throw water on your fire, okay? I'm really interested in this modification that you've made, and the job indeed looks well done. I am just curious about it's purpose. Is this intended to extend the bed of the lathe so you can turn longer items?
Norm Smith in Nova Scotia
>Dale, That is a terrific setup. Looks like the answer. I have a stand alone outboard tool rest setup made from an old machine stand which is as heavy as old heck. I must try to rig one.
Thanks,
Norm
Mike from St. Clair Shores
>Allen,
I believe that the purpose is to put the tailstock on the newly added post, and pull the headstock down to that end to turn larger diameter items.
IMHO,
Mike
>Dale I like that much better than mine. Simple construction which is good. If you put a swiveling plate on the bottom so you could loosen one bolt and let it pivot on another you would be able to move the tool rest left and right as well as in and out.
Dale Cook
>Hi John, that's a very good idea. That would make it very easy to get a good line-up of head and tail stock. I thought I could shim one side of the mounting plate if I had to,but your idea would be much quicker. Hi Allen, the main purpose for this is to turn larger diameter pieces and use the tailstock for extra support. I believe it has a 62 inch capacity in this set-up.
Re: Thanks, Mike, I understand now.
Allen Neighbors
>And in that case. I think it's an awesome addition to a fine lathe. Hmmm... that makes it possible to turn a 6-8 foot dia bowl... You'll be able to make your own bathtub!!! (Big guffaw here)
