Have a question? Ask Woody!
Keith Tompkins- GageT question
Steven Antonucci
steve antonucci
>I like the idea and prototype designs you've posted, but does the "measurin" side of the caliper have a lock for that little spindle so that it can be locked at the maximum thickness (or some other preset measurement?
Seems like a thumbscrew might be a neat v2.0 upgrade if it doesn't already have one...
Steven
Re: Keith Tompkins- GageT question
Re: Looks like a perfect location....
Russ Fairfield
>... for a dial indicator. One of those coarse reading ones that is graduated in 10/1000 or 1/64 incremenrs.
Might as well go with digital readout :)
Why not go with a GPS system mount on your
Denis Putland from Saskatchewan
>gouge and then there is no need for measuring gagets or laser ect.!!
Denis
Re: There is an advantage to a dial.
Russ Fairfield
>John, I prefer the dial and needle because I can watch the movement of the needle as the gauge is moved across the surface. That is mopre difficult to do when there is nothing but numbers flashing by.
Mine are so perfect theres's no flashing:)
Think KISS works best...
david
>At first thought a thumbscrew to lock the measurement down seems like a great and relatively minor adaptation, but what if the measurement is taken near the bottom of the bowl, locked down, and then you are not able to remove the caliper because the rim area is thicker? Also, any high-tech "improvement" should also result in increased cost of the product. I have ordered one and it is on its way, and my only concern is the readibility of the scale, which I will find out in due course.
Keith Tompkins
keith tompkins
>HI Steve, I considered installing one, but there is no set-screw or thumb-screw. It would add to the cost, and the gauge is so easy to read, it's really not necessary. I may consider it on a later version; I discovered a huge potential customer base for the tool....potters! The gage is being used in pottery classes to help students guage wall thickness...a lock has been suggested by a few potters as well.
Keith Tompkins
keith tompkins
>Russ, The graduations work in much the same way...very easy to read. However, a dial indicator would work nicely with minor modifications, but is a bit of overkill..you would certainly have the world's most accurately turned wood bowls.
Dial indicators are sensitive...a thousandth of an inch is one complete rotation of the needle on the dial on most indicators. Even a sixteenth of an inch would drive you crazy trying to read it.
Are the steel parts stainless for the potters?
Jamie Donaldson
Russ Fairfield
>I was thinking about a dial with 1" per revolution. They are available.
Keith Tompkins
Re: Are the steel parts stainless for the potters?
keith tompkins
>Yes Jamie, I have a number of them in stock...they are an option, but they're expensive.
