New Tool:Tompkins Bowl Gauge
Keith Tompkins
keith tompkins
>As some contributors on the site know, I've been working on a new, completely different line of woodturning measuring gauges. Here's a photo of my production model bowl gauge. I have designed a whole series, including a platter gauge, deep vessel gauge, and spindle-turning gauge.
I started making these a few years back; my spiral forms and rose pieces could not be measured accurately with conventional calipers, so I was forced to invent my own measuring tools as well. I've created several different variations for specialized usages; my original tool frames were made of baltic birch plywood, the production pieces are cast urethane resin. My wife chose the name "Gage'T", an abbreviation for "Gauge it".
The majority of production was done in-house, in colaboration with Giles Gilson. We worked together to refine the design, sculpt a master, and create molds for casting the frames. I may post a few photos of the process. If you think turning is an expensive hobby...try becoming an inventor!
The brass balls on the gauge ride against the walls of the bowl being measured, a floating calibrated pin rides the exterior of the form, giving an exact measurement...even across the bottom.
I'm not posting any ordering info to avoid a conflict....I've spoken with Ellis, and plan on advertising my tools here on WC. I will, however, be demonstrating the gauge in Portland.
Re: New Tool:Tompkins Bowl Gauge
I Wanna!!
Jorge Castaneda
>Keith,
That looks really good. Hope you will be selling soon.
Jorge
Jim Shaver - Oakville, Ontario
>Hey Keith,
Can you use it for laying out dove tails.. :-)
All the best with your endevours.
Take Care,
Jim
Re: Keith- my only concern is ...
Jamie Donaldson
>.. the non-discriptive name? I can understand you wife having input, but something like "T Gauge" would have meaning on several levels to your buyers- Tompkins Gauge, Thickness gauge,etc. Gage is not even a word in the current vernacular?
I share Jamie's concern ...
Ed Moore
>that the name doesn't fit the tool. Look at your own headline for this thread - "Tompkins Bowl Gauge". Right there says it all. Call it what it is. Name recognition counts.
I hope that you sell so many that the Connecticut economy is thrown out of balance. ;^D
Ed
Doug Thompson near Cleveland
>Good one Keith, show us a picture(s) how it works on a bowl. If someone wants more information let them email you.
We need more pictures...
Allen Neighbors
>What is the largest size bowl it will the GageT guage, Keith?
Bill Neddow
>I posted a review of this tool over at WoW in the "Reviews" section. If anyone wants, I can post it here. Great tool.
>Keith I read the review on Wow. Sounds excellent. It looks too much like the gauge the use to measure body fat. I have a degree in Physical Education and spent way too much time with one of those. Based on todays kids you need a much larger version.
Seriously, I'm saving my money. I have a bunch of homemade devices and they work for me but I'm reaching the point where I need to work faster and that sounds like the tool that will let you do that.
Keith Tompkins
keith tompkins
>Here's an image of how the tool can measure the base of a bowl. Sorry for a bad image, but you can see how it works. The balls won't scratch the surface of the bowl, and compensate for slight user error. the gauge is direct reading, nothing to interpret or mis-read. The gauge will measure to the center of a 17"diameter or slightly larger bowl...and will measure the walls of a 20" bowl while in the chuck. Any shape that will fit within the frame can be measured. I designed it to work on most bowls capable of being turned on a 20" lathe. A mini-lathe version is in the works, possibly a larger version if demand warrants.
david
>Don't mean to state the obvious, but the frame must have the ability to expand to remove the device once the measurement is taken, and will have sufficient memory to return to the measure taken clamped down mode once flexed and removed from the vessel?
Keith Tompkins
keith tompkins
>David, the frame doesn't move at all. The only moving part is the spring-loaded measuring pin that rides along the outside of the bowl. If the balls touch, the thickness is zero, naturally. If the balls are one inch apart, the wall thickness is one inch. The frame doesn't have to be opened up at all as the tool is swung from the rim to the foot. Hope that helps.
Re: So... you measure the....
Allen Neighbors
>protrusion of the pin? Or are their markings on the spring-laded pin?
Re: Duh... Disregard... I re-read your post.
Allen Neighbors
Keith Tompkins
keith tompkins
>Hi Allen, There are graduated marks on the pin, in 1/16" increments. If the wall thickness is 3/8", for example, that is the measurement the pin protrudes past the frame. As the tool is moved around the bowl, you can watch the pin move in or out in relation to wall thickness.
This Tool Works!
Don Orr
>I have also seen this tool in action and it works as described. Smoothly and easily. Direct reading, no fuss, no muss. I remember Keith's earlier versions in wood at one of our club meetings several years ago. It's great to see this come to market in such a nice way. I'm looking forward to the other versions now. Excellent collaboration from 2 very talented, skilled, and creative people.
Peter Hyde
>I can't help but think Keith has come up with a very clever play on words here. Unfortunately it seems to be over the heads of some:-)
Read the name as GADGET without the D and it becomes GAUGE-ET or in the new text message lingo GAGE-T. Congratulations Keith on a very clever and sound piece of equipment, and also a very clever name.
ReYes Peter- so far over .....
Jamie Donaldson
>.. our heads that it is meaningless! In language analysis you don't have the option of randomly adding or dropping letters, even if they are silent, without affecting the meanings of words.
Re: Jaime,
Allen Neighbors
>If you'll notice, he has it spelled Gage'T... there is an apostrophe between the e and t.
Congratulations!
Jennifer@Indy.USA
>Keith,
I remember when I saw this at your demo here in Indy a few years ago, at our club that I just knew it was going to come to fruition one day. Its a great invention and I wish you all the best!
Jen
Brad Vietje
COOL Daddy-O !!! Keep us posted !
Brad Vietje
Keith Tompkins
keith tompkins
>Hey Jamie, Sorry if the name bothers you; however "gage" is truly a proper word. According to the American Heritage Dictionary of the English Language, GAGE has several meanings:
1. a measuring instrument for measuring and indicating a quantity, such as the thickness of a wire, or amount of rain, etc.
2. a security obligation
3. a challenge
4. a pledge of security
5. to offer as a stake in a bet or wager
6. a type of plum, such as greengage
7. a variation in spelling of the word "gauge"
I took the advise of a dear friend who spent a career on Madison Avenue in naming the tool. According to him, people won't remember a person's name, but they will remember a catchy phrase or logo. One only has to watch a bit of TV advertising to see that philosophy firsthand. "Turning is supposed to be fun...come on man! Lighten up! Give this thing a catchy name...people will love it!" Hence the name "Gage'T". BTW, yes, it is a play on the words "gauge" and "gadget".
Keith Tompkins
keith tompkins
>"T" stands for tubby? hmmmm
Keith Tompkins
keith tompkins
>Thanks all for the words of encouragement! Much appreciated.
Re: A catchy name is an asset, but...
Jamie Donaldson
>... it should be descriptive to form an association with the product and function. The missing "i" and archaic spelling of "gage" makes the name play rather obscure- not immediately clear to the buyer what it actually is and does, especially to your target audience. Not my problem- enough said! ;-)))
