REAL MILK PAINT
Why?....
Why?....
Why?....
Wally Dickerman in Arizona
>Most of us have turned spin-tops. I once turned a hundred or so at a kids day in the park. I gave then away as I made them...had kids lined up.
Question...Did you ever notice that when the top wobbles, then falls over, before it comes to a stop it reverses direction? Why does it do that?
As you can tell, I have important things on my mind this afternoon.
Wally
Re: Why?....
Re: The answer is "because....!!!
Jamie Donaldson
Re: Why?....
Re: Why?....
Don in Central Illinois
>Because at the tip of the top (the part actually touching the table) does not have enought contact point to matter. When if falls over, the outer part of the top, turning clockwise, now hits the unmoving table and therefore turns counter clockwise. Good think it's a little slow at work today and I had time to figure this out. Whew.
Re: Why?....
Re: It's magic.
Russ Fairfield
>It's "magic".
Why can't we leave it that way?
One of the problems with this modern world is that everything has to have an explanation.
There is no "magic".
Re: Why?....
Re: Why?....
C.W.Stivison
>Magic is being as young as Wally and still be as talented him.
CW
Re: Why?....
Re: Why?....
Rick Davenport
>The result would be the opposite if you lived in the Southern Hemisphere!
(yeah right)
Rick
Re: Why?....
Another magic trick....
>I have no clue aobut the top and am happy to leave it as magic.
Here another one:
Take you claw hammer and hold it out in front of you level, holding it by the end of the handle. Have the head level left to right so that the head is on one side and the claw is on the other. Flip it so that the handle flips around in the same fashion a table saw blade turns when the blade is ninety degrees to the table. One revolution and catch the handle. Notice the head is now on the other side.
Re: Why?....
osmosis ......
Bill Stehman
Re: Why?....
Vortex
dwr
Re: Why?....
not it's not, it hits you in the foot. :)
Re: Why?....
Every Action has a reaction?...
Re: Why?....
Re:I'm reading a story in a.......
Jamie Donaldson
>.... magazine that has the answer! When the spinning object reaches the RPM that causes the spinning object to lose balance and touch the rim against the supporting surface, this action is called the moment of inertia(MOI) When the 2 surfaces meet, there is a reaction called the coefficient of restitution (COR) which results in a rapid reversal in direction as the 2 surfaces move in opposite directions. Sounds good to me, and I'm reading Golf Digest! ;-)))
Re: Why?....
Re: Why?.... *LINK*
Mike from St. Clair Shores
>Wally,
Have you ever made a rattleback?
There very cool. Google has a lot of examples
but here's a link.
Later,
Mike
Rattleback
Re: Why?....
Don Tewell
>I thought that's what I said earlier.
Re: Why?....
Yeah Jamie...
>I've had a lot of golf balls that went into the cup and spun back out again. Now we know...it was because the ball changed it's spin direction.
Wally
Re: Why?....
Strobe Effect
Jorge Castaneda
>Wally, I think they only appear to reverse, something like the strobe effect that happens whith turning wheels.
Re: Why?....
Somethings best left unknown...
Fog Tanner
>There are somethings best left unknown. Einstein once said "the most beautiful thing in the universe we can percieve is the unknown". Part of the fascination of the top, like a lot of other things, is not knowing. There is the illusion and mystery of the unknown. remove the veil and what you thought was something beautiful maiden is in reality an ugly hag. Reduce the night sky to a series of mechanics and it quickly looses it allure and with the loss of the mystery, so is the beauty.
Some mysterys are best left unknown and as Russ said "leave it to magic", enjoy the mystery and the beauty that it holds. So why does it reverse, magic.....
Re: Why?....
Re: Fog is definitely not an engineer!! ;-)))
Jamie Donaldson
Re: Why?....
Fog Tanner
>Software engineer is what is in my description. Software developer among others. But, my favorite is still systems programmer - but that is from another time when it meant much more than today. My vocation is to deal in absolutes.
Even within my world so full of definitive ones and zeroes, there are still certain aspects that are always a mystery when you start and some when you finish. What may work without incident on a sigular basis takes on new characteristics under volume stress. Often the results are documents and publish as facts, without ever knowing the intricate interactions that happen at high reates of traffic. Much like the universe, theories put forth as factual without the absolute proof. They are merely observations made by a being whose senses are flawed and not aboslute, so his findings cannot be absolute.
After over 100 years of flight and the theories why wings work, the engineers finally came out a while back and said that what we had believed was wrong. Wings did not generate life for the reasons that had been put forth. They did not know why they worked, only was believed was wrong. Back to the unknown and once again the flight of a bird or a glider is a thing of beauty - it is an unknown - or as Russ would say "magic"...
Re: Why?....
Re:Fogg- I like your outlook! I was.....
Jamie Donaldson
>... raised in an environment dominated by engineerspeak (my Father and Grandfather) but turns out I'm a bit dyslexic and had to get married to get my checkbook straightened out! With degrees in Philosophy and Social Psychology I seldom deal in absolutes either. Some things should have an element of mystery, if for no other reason than to keep life interesting!
