Need Help with Cedar Log
Charlie Anderson
>I have this log but don't know how to use it. It's eastern red cedar. very aromatic.
It's end is 13 x 15 and the length is 17 inches.
Any suggestions on how to best use it.
Thanks
Charlie Anderson
Thanks
Re: Need Help with Cedar Log
Don in Central Illinois
>That is obviously a faulty piece of wood, what with all the smell and the red in the center. Maybe you should just send it to me and I'll dispose of it for you. Seriously, I have some similar to that and have it sitting around because I don't know what to do with it either. Looking forward to the experts that can help both of us.
nailshooter
>I like end grain (turning parallel to the ways) for the most part more than the normal style of at 90 degrees to the ways. To me, this piece of wood should have at least part of it "end turned". I had a piece of walnut that was almost black it was so dark and the sap was light blonde.
End turning with the wood slightly off center made a wonderful piece as it opened up the grain tremendously into roller coaster tracks around the piece. The blonde sap wood made a lovely rim.
Robert
Ken Oakley-Sunny St. Cloud, Fla.
>I obtained some of the same recently and I sell a lot of citrus, orange,grapefruit, tangerine, on Ebay. I cut the woods to pen blank size and have done very well selling the stuff. So I cut most of the cedar logs into 1" slabs and then some into pen blank size and have been selling some of it that way. Really spectacular color and graining.
Rick Davenport
>If I had this log, I would would make two cuts lengthwise to remove the pith.
If you make the cuts an inch or two apart, you now have a bit of a slab for pen blanks and such.
Then I would turn two natural edge bowls and sand them to 600 grit.
Sand lightly and gently or the heat will make the bowl develop lots of tiny cracks.
I would put NO finish on the bowls at all.
This way the smell will come through and last a long time.
I've sold a number of these type bowls to folks who have big walk in closets.
I guess they want to dress up their dressers.
And it wouldn't hurt to fill the bowls with cedar shavings for an even more aromatic bowl.
Rick
MIke from St. Clair Shores
>Charlie,
I would turn this piece end grain. Put it between centers with the pith about an inch from center at the headstock side. Turn all the bark except for about 2-3 inches at the tailstock side. Then start to shape it like a natural edge vase, I've included a picture to make it more understandable. (is that even a word?)
Mike
Thanks everyone
Charlie Anderson
>I'll probably do the natural bowls.
I have a smaller log to try the natural edge end grain bowl.
