Box Threading Jig *LINK*
MIke from St. Clair Shores
>I saw Al Crandall's threading jig last year on his club's web site. I've wanted to make one ever since. So this past week-end I decided it was time. I had a cross slide vise that I got at Rockler a while back and decided to use it in the jig. I also used an old bosch router and scrap wood that was in the shop. The only things I had to go out and buy were: 1" x 8" all thread rod, nuts to fit the rod, and a cutter that Al described. The rod and 6 nuts were $12.00 and the cutter was $22.00. I've made 3 boxes and it cuts great. I own hand chasers but they don't work well with most of our domestic woods. So far I have used cherry, maple, and mahoghany and they all cut great. Oh yeh, the chuck came off my midi. but you can use face plates and glue blocks. I want to make two more boxes that hold different size threaded rod, so you can cut different size threads. Comments Welcome.
Threaded Box Jig
Re: Box Threading Jig *LINK*
Good Job!
Jorge Castaneda
>Mike,
that jig came out right, when you have something to show the results please post.
Thank you
Jorge
ps, where did you buy the cutter?
John Kyler
>Where can one get the cutter/bit?
Thanks
John
Re: Good thinking. I have two suggestions.
Al Crandall (N.E. of Indy)
>I'm a fanatic about tolerances, and the fit between all thread and grade 2 nuts is too sloppy for my tastes. I included a spring to apply constant pressure on the floating nut to remove any backlash in the threads. The second consideration is having enough room between the cutter and the work piece to be able to trial fit the first piece into the second one. On the three jigs I've made I had provisions to enable me to take the "tailstock" off the jig and return it to the exact place relative to the lead of the thread already cut. On your jig, it could be something as simple as two blocks of wood fastened to the bottom of the box, one on either side of the vise throat. Then you could easily unclamp the box and reclamp it accurately. Again, nice job of material utilization.
Bill Clark
>Thanks for the great photos. Great job. I'm really into jigs and might make one of these. What diameter and thread size is the shaft and where did you get it. It doesn't look like one the corner hardware store would stock. Maybe you could post a few tips on the steps you took to produce this little gem. Thanks!
Chris in KC
>Great job, Mike. Please share any sources for the hardware and if there are plans available, please let us know. I'd very much like to try my hand at one of these.
Al C.- If you have any additional info on this jig, I'd sure like to get it from you.
Thanks for posting.
-Chris in KC
Re: Box Threading Jig Additional Info.
>I can't do links, but copy and paste this:
http://www.cicaaw.org/image/tid/105
Click on the thumbnails 1373, 75, 76, 77, 78, 79, and 81. When each opens, you will find a detailed account of what is being shown in each picture. Many thanks to James Purciful for shooting the pictures and managing our club's website.
Al's link  *LINK*
Jorge Castaneda
here
>Al,
First off, thanks for all the info that I originally got from you on your club's site.
I really wanted to put a spring on the allthread but I wasn't able to find one. So I assembled it without, thinking I can always add it when I find one. As far as the tolerances, I don't know if it's the hard maple the allthread goes thru,(this was a very tight fit and I made threads in the maple when I was turning the rod into it), or that the nuts I bought seemed to have a very close tolerance because when I put them in the box on the rod they didn't move. Your second point about fitting the lid is also a good one. I could have made the jig longer, but I figured that between the cross sled adjustment and where I grab the box in the jaws I have 12 inches from the chuck to the cutter. In the future if I need to make bigger pieces with threads I will definitely make a longer jig.
Thanks again,
Mike
>Bill,
By now you may have seen the links to Al's jig. Beneath each of his pictures he descibes everything. He list where he got it along with item #'s. I would not have made mine if he hadn't already done all the work. He list Enco as one source. Since I have a Wholesale Tool in my area, I just went to them and asked for the same items. They had it all.
Good Luck,
Mike
Re: Good Job!
>Jorge,
The cutter info is listed under picture 1373 in Al Crandall's explanation.
Here it is:
The cutter shown in the router spindle is a 3/4" diameter 60 degree hss Double Angle shank type cutter with a 3/8" diameter shank. It was purchased from Enco. Their model number is 367-7100. On line shopping at www.use-enco.com will get it for $21.24 plus shipping as of this writing. Be aware that the 3/8" shank will probably necessitate the use of a collet bushing in the router. Another option would be to buy a 1" diameter cutter which has a 1/2" diameter shank. This cutter number is 367-7102 from Enco. I know of no source which has a like cutter with 1/4" diameter shank.
Thanks,
Mike
>John,
The answer you are looking for is below this one in response to Jorge's question.
Mike
Re: Good Job!
Jorge Castaneda
>Thanks Mike'
I have all kind of routers and prefer the ones with 1/2" shanks for many reasons, but for this job a 3/8" is enough and the jig will be smaller than with a bigger router.
I'ts going to be fun!
hanks again
Jorge
