>O.K. I'm finally ready to pull the trigger on a vacuum chucking system. I know this subject has been covered ad nauseum here and elsewhere, but I'm not sure my situation has been.
I'm an O.K. woodturner,but I don't have a lot of extra time to devote to plumbing and fabricating, etc.
So..does somebody sell an all inclusive "kit" to set me up, or do I have to buy everything ala carte?
Lathe is Oneway 2436, and I want a vacuum pump as opposed to a compressed air or shop vac system.
>... for some of the parts in a kit form. You can get affordable vacuum pumps from several sources. Making your own shellac sealed MDF chucks with some neoprene is not hard to do, since you already turn.
>These companies sell all of the components that you'd need. Take a look, pick one that you like and send them an email. I'm sure they'd be happy to put a package together for you.
>A while back, I got my vacuum set-up from Johnny Tolly , which included vacuum pump, all fittings, gauges, and hose. Only thing missing was the vacuum bearing, which on my Nova 3000 I never got right with Nova parts until I switched to the EZ vacuum bearing I got from Packard. Then everyting fell together--worked like a charm. I then switched to a Vicmarc VL300 and the only thing I had to change on the vacuum setup was the threaded lamp tube--a different length was needed for the Vicmarc. Don't know if Johnny continues to sell these setups. Believe that Barbara Gill was also a John Tolly customer.
