So whaddo I tell them?
David Breth
>In about a week, I'm going to do my first craft show, which should be highly entertaining on a number of levels. I've been putting things together bit by bit (borrowed a canopy tent from a friend for example), and have been spinning wood like a madman.
I've also been trying to anticipate some what-ifs. The biggest what if that I just can't answer is regarding the care and feeding of a bowl when it is used for salads, popcorn, etc. My answer was going to be "Just use it as a candy dish. Stuff in wrappers. Keep it out of the sun." Can you folks assist here a little bit? I recall at one point ages ago somebody posted about a little card they handed out with care instructions, cleaning, etc.. The most I can think to say is the second you start in on it with a fork is when the finish will stop looking nice. And keep it out of the sun.
By the way, nearly all of my bowls are finished with Minwax Antique Oil Finish.
Thanks -
David B.
Re: So whaddo I tell them?
Re: A little handout.
Allen Neighbors
>David this is what I hand out with utility bowls, that have had a polymerizing finish put on them.
To keep your bowl like new:
After using the bowl for food items, do not let it stand for a long time. As soon as you�re finished eating, wash it with warm soapy water, rinse well, and towel dry.
To season your bowl after it has not been used for a while:
After you have used your bowl, sometimes after sitting for a period of time, some grains of the wood may raise a little, causing some rough areas to exist. If there are some rough spots, smooth them out with #0000 steel wool. Wipe it out. Wash it with warm soapy water, and towel dry. If it seems like it needs to be �sanded�, after washing, put in a spoon or two of salt, and be gentle: scour the inside with a paper towel, using the salt as grit to �purify� and clean the inside. Rinse, and wipe it dry.
Note: DO NOT use Mineral oil, or extra-virgin olive oil, or any type of vegetable oil. http://www.gi.alaska.edu/ScienceForum/ASF11/1121B.html (This explains that Wood is better than any plastic for food items) Quote: Research Scientists smeared wooden boards with about 10,000 cells of Salmonella, Listeria, and Escherichia coli, cultured bacteria. That's about 10 times the number of organisms that typically wash off a contaminated chicken carcass. Within three minutes, 99.9 percent of the bacteria were unrecoverable and presumed dead. By the next morning, the researchers couldn't recover any live bacteria from the wood. Next, the scientists upped the germ count, inoculating the boards with a million or more bacteria apiece. Then they had enough survivors to work with, but not for long. Within two hours, again 99.9 percent of the bacteria had vanished. The only thing they've found that does enhance bacteria growth is treating the wood with mineral oil.
Russ Fairfield
>Bowls that smell like paint thinner will invite the question about safety. The best answer is the simple answer. Tell them to use the bowl, and DO NOT PUT IT IN THE DISHWASDHER.
That's it. There is nothing more to say. A wooden bowl will survive almost anything they want to do to it. Men are stupid in the kitchen. Women aren't. They know how to take care of a cutting board. Tell them to do the same thing with the bowl. It will be fine.
The biggest problem with selling bowls is trying to sell bowls that smell like paint. We all know that all finishes are absolutely edible after they have cured and all of the thinners and solvents have evaporated. That means they don't smell like paint thinner.
Bowls that smell like paint thinner will invite the question about safety. Complex explanations and qualifications are a sure way to drive people away.
If there is no odor to your bowl, you will never be asked about whether it is safe. And, just in case you are asked, you can answer, "Yes, it is absolutely safe to use for food service." And there is a world of scientific evidence to back that up. Remember that shellac is a food, and all the other finishes are inert and will pass through our body as though it were a piece of plastic
Smell can be a positive sales pitch. First make sure there is no finish odor. Then wipe little Hazelnut Oil from the kitchen gormet shoppe on the inside of the bowl to give it an appetizing odor. Works every time.
Good luck with the sale.
Ron McKinley
>Great handout Allen. If you don't mind I'll use it for every bowl I give away. Thanks........Ron
Sage advice. That's what we expect from Russ!
david
RevDoug
>Thanks for those great words, Russ. You are a wise sage.
Turn 'em round,
David Breth
>Thanks very much for the responses. I certainly appreciate it.
I won't have a great deal for this show, at least I don't think so. I'll have about 38 bowls, 4 pot pourri bowls, 2 lidded boxes, and that's about it for lathe items. I couldn't motivate myself in February or March to spin, and my inventory reflects that. To supplement the table, I've made 77 little cars (about matchbox car size), and my wife is making rice bags (you heat them up, etc.) My biggest concern, and I think it is legit, is that if I sell ten items I'm going to very suddenly look picked over and thin on inventory.
I've also made up a very brief binder of "how a bowl is made" with a few basic pictures that tell the story. Plus, I've put in photos of non-lathe items I make such as toy boxes and board puzzles, and you never know, maybe somebody will want me to make something for them.
This is the grand experiment. Maybe I walk home in possession of everything I had when I started, and I learn that my friends and family like gifts but my work isn't good enough to suit the public. Or maybe I sell out and learn that I need to bring more of _____ and less of _____ in the size of ______ and shape of _____. I'll be taking careful notes on what moves & what doesn't.
Anyway, thanks once again for the advice!
David B.
Mark Paulley
>Russ,
Just to calrify and I hate to sound too stupid. You mean a bowl with 50% deft and 50% lac thinner can be used for food usage?
Mark Paulley
>David,
I too am just starting the craft show circuit in my area. I sold stuff at the first I would have used on the burn pile. The second show I sold the samall things and third show I sold the bigger bowls and again the stuff I would not cart home. Some items I would not have taken to the show but utilizing my wifes suggestion of pricing items low that I HATED, I sold those and made a healthy profit. Better to make a few bucks then burn the stuff. The old wise tale: one mans treasures is another mans junk! Go Figure!!!! Just keep records per show of what sold. Each show is different and the people that attend are different. Again GO FIGURE!!!!
Not an artist just a turner with tooo many bowls and not enough friends to give them to!
Mark
Re: Yep, When it's cured, it's safe.
Allen Neighbors
Mark Paulley
>Allen,
Thanks for the info. Maybe I can sell a few more bowls now. I have been telling people no way for food! I will hear the cash register ching a ling now!
Thanks again!
Mark
Re: Mark, I use a wash, consisting
Allen Neighbors
>of approximately 25%Lacquer/75%Thinner on most of my pieces, including utility bowls. I use the wash mostly for the protection of surfaces from CA, around small cracks and filled areas. The wash seals the wood, which keeps the CA from staining it, and what remains on the surface is usually sanded away during the sanding process. Later, depending on the piece, I can use a normal lacquer finish, or a Danish Oil finish. The Danish really makes the grain pop, even after using the wash. Most of the time, if I don't plan a Lacquer finish, I wet sand the final grits 280/320/400/600 with Danish.
Re: PS: I love Russ' suggestion
Allen Neighbors
>about the Hazelnut Oil. Now I have to wait until I need to make that 115 mile trip to the city, in order to locate some. :)
Thanks, Russ!!
Mark Paulley
>Allen,
Again thanks for your help. If you are ever in the Loisville KY area please give a call so we can meet and swap stories and such!!!!
Mark
Re: You might want to rethink your marketing plan
Russ Fairfield
>Somebody has to say this.
Mark, you might want to rethink your marketing plan. Selling crappy turned wood that you wouldn't want to take home yourself to people wo don't know the difference is not a good way to get started in selling turned wood.
There are a lot of problems with "selling one man's junk as another man's treasure". The biggest problem is that it is not going to get you a reputation as a quality woodturner. In a local market, you will have already established your reputation as the low priced alternative. It will be difficult if not impossible to raise your prices later when you get better and start turning better quality. Lastly, selling low quality gives woodturning a bad reputation, regardless of what you are charging for it, and a bad reputation serves nobody.
