What do you use to remove Anchorseal?
david
>I painted some end grain sealer on a nearly finished piece and was wondering what others use to remove the stuff other than sand or scrape it off. Thanks for your comments.
Re: What do you use to remove Anchorseal?
Cyril Griesbach
>David, I'm guessing that you're going to remount and finish turn this piece so what ever tool you use should take off the wax. Also, I believe I've heard that mineral spirits will take it off but I'm not sure .
david
>Thanks for the suggestion of using mineral spirits. The bottom was already sanded smooth and the Anchorseal was applied to get a better suction on the vacuum chuck. Was looking for something that avoided further sanding or minimized any kind of scraping.
Peter Teubel
>Plain old hot water will also remove it. In the future, you might want to use a coat of whatever finish you are using to get a better vacuum seal.
>Since Anchorseal is an emulsion, the emulsifier remains in the wax film. Most of it will come off with a hose, but a little soap and water will remove it completely. Powerwasher is quick if you have one.
Jimmy Edwards
>My wifes hairdryer works real well. However very risky. Cutting torch works too. A little heat and it runs.
Thanks to all for your comments!
david
Steve Worcester
>The other problem you may run into is the finish. Since it is a wax, without completely removing the wax, including what has soaked into the pores, you can only use a wax finish over the top.
Acetone will most likely remove the top coat, but is a fairly volatile way to do it.
