It's OFF!!!!!!
It's OFF!!!!!!
It's OFF!!!!!!
Ruth Niles
>Thank you ALL for the advice and suggestions. This morning before I went to the neighbor's (I have a really hard time asking for help), I tried 3 things again. First I put my 12" pipe wrench on the face plate nut, then used the (ready?) pipe from my bandsaw that holds the fence (it was the only thing I had that fit over the wrench handle) and tried lifing from the back, an excellent suggestion from one person here, didn't work, but a good suggestion; bent the wrench handle. Then I put bolts into a 2 X 4 X 28" long, gently tapped the bolts into the holes in the face plate (gently but using not so gently words), hit the end of the board with a small sledge hammer. The bolts bent and the wood cracked.
Then I put ice on the spindle, heated up the face plate until steam was pouring out the hand wheel, put the General wrench on and whacked it with the sledge hammer and that darling little face plate just surrendered. WHEW!
Re: It's OFF!!!!!!
Re: It's OFF!!!!!!
Bill Hale / The Wood Spinner
>Pretty smart those Chinese Eng.
Glad you got it Bill
Re: It's OFF!!!!!!
Re: It's OFF!!!!!!
Bill Howatt
>Glad you prevailed! I (usually) always have a thin plastic washer made from a margarine lid on my spindle. I drill a 1-1/4" hole with a Forstner bit and then cut around it making a wall of about 1/4".
I've never had any reason to suspect it is causing the faceplate or chucks to run out of true.
A bit of lube on the surfaces might be another alternative. I believe there was a big thread on this about a month or so ago.
Bill
Re: It's OFF!!!!!!
Hip-hip-Hoooooray!
Jennifer@Indy.USA
Re: It's OFF!!!!!!
Woooohooo!!!
Ken Grunke from SW WI
>Waytogo girl, I knew you could pull it off! Maybe it was the harsh words that helped ;)
I'm convinced that attitude has much to do with solving problems like this. It's only mind over matter, having the proper tools, plus a bit of cussing that made your victory possible.
Congratulations Ruth!
Re: It's OFF!!!!!!
Re: It's OFF!!!!!! *LINK*
Wilford Bickel
>Ruth,
Glad you got it off!! The product I have found that works best in my shop to prevent freezing up and corrosion actually is a product I use with my guns. It is called Firepower FP10 and actually "bonds" with the metal and once you wipe off the excess it leaves no residue to get onto the wood. Knock on wood - I've not had a stuck faceplate or chuck since I took this out to the shop and started using it on my tools and well as my guns. The company is located in PA and will sell direct - I order mine direct from them. Try it and keep your threads and bed of your lathe coated with it periodically.
Firepower FP10
Re: It's OFF!!!!!!
I'll drink a brew for you this afternoon.
Re: It's OFF!!!!!!
Glad to hear!
Jorge Castaneda
Re: It's OFF!!!!!!
Re: It's OFF!!!!!!
Doug Thompson near Cleveland
>Way to go! This made my day.
Re: It's OFF!!!!!!
Ric Taylor
You Bent a Pipe Wrench Handle???
Ric Taylor
>OMG Ruth, and you impressed me as being a gentle lady.... :)
Ric
Re: It's OFF!!!!!!
Re: It's OFF!!!!!!
Ken Oakley-Sunny St. Cloud, Fla.
>After that kind of treatment I'd surrender too!!!!
Re: It's OFF!!!!!!
Re: Woooohooo!!!
Ruth Niles
>You're right, Ken, sometimes "darn" just doesn't cut it! : )
Re: It's OFF!!!!!!
What a Guy! I just may do the same.
Ruth Niles
Re: It's OFF!!!!!!
Re: You Bent a Pipe Wrench Handle???
Ruth Niles
>Ric, I am a gentle lady, there are situations that call for a slight bit more than "gentle". : )
Yes, I bent the wrench between the jaws so now I can't close the jaws on the pipe wrench. Better a pipe wrench than the General!
Re: It's OFF!!!!!!
Steve Kubien
Re: It's OFF!!!!!!
Steve Kubien
>Ruth, I've been following this little saga without much to add to the great advice you already received. Glad to hear you conquered over that little bit of steel! Have you investigated preventative measures to be sure this doesn't happen again?
Cheers,
Steve Kubien
Re: It's OFF!!!!!!
Leo Van Der Loo
Glad to hear you got the faceplate off of the
Leo Van Der Loo
>General, and don't forget how it got stuck, You should know "haste makes waste" Ruth, yes easy saying from up here right.
Ruth, take a good close look to see if there is any scoring on the mating surfaces, if so get them cleaned up and polish smooth, so they are not grabbing.
Take a break and have fun, take care
Leo Van Der Loo
Re: It's OFF!!!!!!
Steve Kubien
Steve Kubien
>Yup, sure beats replacing a lathe (although the shopping might be fun).
Nice work.
Steve Kubien
Re: It's OFF!!!!!!
jeff myroup
>Remind me to never piss off Ruth. I am 6'5'' and 265 lbs. I have never bent a pipe wrench! Glad to hear you got it loose. Fire beats steel every time.
Jeff
Re: It's OFF!!!!!!
You da wo-MAN!!!
Molly Winton
Re: It's OFF!!!!!!
Yes, Steve, I'm never going to
Ruth Niles
>try to part a 6" diam. piece of dry cherry with a little bitty fluted parting tool. That tool caught about 2 1/2" in, the wood flew off the face plate, bending 2 of the 5/8" bolts holding it and the face plate slammed tight and locked.
Never did that before and never will again!
Re: It's OFF!!!!!!
Re: Glad to hear you got the faceplate off of the
Tom Storey
>Leo has a very valid point here! Remember what it was you did that got it so dang stuck in the first place and NEVER do that again. And I'm glad the 'General' is still in great shape!
Tom
Re: It's OFF!!!!!!
Re: I'd give a lot to see a closeup picture of
Al Crandall (N.E. of Indy)
>I'd give a lot to see a closeup picture of those jaws. Curious which way they bent. I have used 6' long pieces of 2" pipe on stubborn screws before and never bent anything.
Re: It's OFF!!!!!!
All is now right with the world :)
Dave Peebles Lyons, Ohio!
>Hi Ruth,
I am so happy to hear that you have resolved the sticky little problem.
I can now go out to my truck and unload all the TNT and slick 50 that I was bringing your way. :)
Glad to hear you got that General to straighten up and fly right!!
Dave
Re: It's OFF!!!!!!
your post has received its own zip code!
Bob Elliott
>Ruth,
Next time you see John Jordan, ask him about his theory on tightening chucks and faceplates.
Re: It's OFF!!!!!!
must have been a chinese tool
>I sprung the jaws of a chinese made open end wrench one time with just hand pressure. I've never done that with a wrench before and have added extensions to them on several occasions.
