shop dust collector
shop dust collector
shop dust collector
ryker acuna
>I have my 16" lathe set up shop in my extra bedroom in the duplex I live in. Does anyone have any options or have the same setup and knows of a good dust collection system I might use? Here is the catch, It has to be fairly quiet and small. Also what would one suggest the cfm rating be for my size lathe. Going the Woodworking Show in my neck of the woods this weekend, maybe I can pick something up. I have researched alot but Im getting big machines and alot, alot of noise. Any suggestions. thnx.
Re: shop dust collector
Bill Howatt
>Don't waste your time trying to get the shavings. I only turn mine on when sanding. I don't know if such as thing as a quiet DC system exists since you are either moving a lot of air either slow or fast (shop-vac).
I have heard the Fein shop-vacs are quiet compared to a regular one.
Bill
Fog Tanner
>In one of Raffins books, he showed a "dust collection" system which was a large floor fan exhausting through a hole in "studio" wall. Since you probably aren't into remodeling the duplex, a couple of box fans exhausting out the windows would probably be better than one of the bag units and a lot quiter. I have an Onedia cyclone, which is a lot quiter than a bag unit (have one of those too) and I would not want it in that size room.
But, I would definately have something in a closed up room that small. I run my cyclone anytime I am turning dry wood. You get a tremendous about of dust off the tip of a gouge, so its not just sanding that can create hazardous air. You can tell when the air starts getting thick and its hard to see your work. Good look in solving your problem.
Is it like you are in a fog?
david
>Sorry, couldn't help myself.
ryker acuna
>I have a small window behind the lathe that will probably work just fine with a box window fan and some hosing. I can put a nylon on the outside or filter and call it done. The window looks out into my enclosed back yard, so that works out. Even so I'll still see what they have at the show this weekend. Maybe it will get me out of the fog Im in. Thanx for all the suggestions.
Re: Is it like you are in a fog?
Fog Tanner
>That would help on those occasions when I have to drive in the Houston traffic, but since that was the name I was given when I hit this rock - I just have to settle for driving when I am not totally awake - easier on my nerves. I would like to die in my sleep like my grandpa - not like the rest of the screaming people in the car..... :-)
>The shopsmith dust collector and the Fein dust collector are the two quietest I have seen. Like others have said it will only collect the sanding dust and small dust. Plan on picking up the bigger chips some other way. You'll also want to seal off the return vents to your air conditioning if you have that. I had a shop in the back bedroom of an apartment once. I cleaned the airconditioning filters weekly.
>Fog, I had an uncle who went through life known as Ness, short for Nest. When he was five years old he broke up a wasp's nest for fun and got stung many times and came home to his mother singing "the wasp's nest is a mess, the wasp's nest is a mess". He lived to be 80. For the last sevety five years he was Ness.
I slso had an uncle Hammer Head. We won't discuss that.
Fog Tanner
>Barry,
I like that. I am from East Texas and familar with names like that, but the first I have ever hear of Ness. And I have a bunch of cousins and great realtives with interesting names, but non like that. I will have to remember that for sure. I am a junior and heard several stories how my father came by the name of Fog, none of which had anything to do with the weather. When people ask me how I came about that name, I tell them that was easy - named after my father.
Over the weekend, my wife was watching a movie was on the satallite. She came out telling me that one of the characters name was Fog, had it on his shirt and everything. Later in the evening we were talking about it, not a common name for sure and I was pondering where they came up with that for name. The character was a mechanic, and well thought of. My father was also a very skilled mechanic and well thought by those that worked with him and those that were in WWII with him. So somewhere along the line his name and vocation made it into the movies. I can only imagine the look if he had of known about that.
Re: shop dust collector *LINK*
Philip Morris
>We recently moved and I have not had a chance to connect my cyclone system. Instead, I have been using a box type dust collector that is small enough to sit on a shelf I installed on my lathe. I can position it right next to the headstock and it collects a surprizing amount of sanding dust. It's not cheap, but it is well built and very quiet. They have various filters that can be used separately and/or stacked for better filtration.
I have no association with the company, nor receive any compensation. Just a satisfied customer. Heres a link to their site.
Razaire Dust Collector
