1/4" Drill Rod on Tool Rest
Allen Neighbors
>This is my toolrest with the 1/4" Drill Rod attached. It looks a little crooked, but it's just the photography. I used PC7, an epoxy substance sort of like JB Weld, only supposedly stronger.
It works so well, I wish I'd done it sooner.
There's such a small area of contact between the HSS toolrest and the HSS tool, there's almost no friction... no nicks, either.
Re: 1/4" Drill Rod on Tool Rest
Re: 1/4" Drill Rod , Closeup
Allen Neighbors
>This is a closer shot of it. The little bowl from a piece of Apricot crotch.
Re: 1/4" Drill Rod , 6" rest setting up
Allen Neighbors
>This is a shot of the 6" rest with the stuff setting up (1 hour working time, 24 hours to cure). I put a long cigarette sized roll of the PC7 on the waxed paper, pressed the toolrest down in the center of it, then pushed the drill rod into the rest of it. The wax paper will peel off, and according to the directions, you smooth out your work with a finger dipped into lacquer thinner. My shaky hands make a mess of things, but it cleans off with 320 and 400 grit, then buff it with Black ebony rouge, and it's finished.
Leo Van Der Loo
Love that little bowl Allen, yes the rest also ;-)
Leo Van Der Loo
>Good job Allen. I may have to try that on one of my tool rests to see how it goes.
What alloy?
Tony Shaftel
>I may want to try that. What kind of drill rod and where did you get it from, if you don't mind my asking?
Re: What alloy? *LINK*
Allen Neighbors
>It's O-1 Drill Rod. Only thing I know about that is it is oil-hardening. I had to score it deep with an old grinder wheel corner, and broke it. Could have cut it with my Dremel, but was out of cutoff wheels, and didn't want to go to Wal-Mart. I'll try to post a link to it. The Enco Part Number is 408-0013
http://www.use-enco.com/CGI/INSRIT?PMAKA=408-0013
Re: Thanks, Leo. Just finished it.
Allen Neighbors
Allen Neighbors
>Thanks, John, I have a piece of 3/16 rod coming that I'm going to use on my Old Griz toolrests. Time will tell, if the epoxy is better than JB or not, but so far, so good. My tools never slid so smoothly on the original edge, even after I'd smoothed and polished it.
tm
>Its beautiful Allen, I may have to try one too.
John
George Van
>Thanks Allen, I have some JB weld and will give this a try this evening. I have read a lot of your tutorials and shop ideas and regrettably do not always have the time to respond but I want you to know that your time spent to organize these is always valued and appreciated. Thanks for posting!
Mike Cunningham Cape May NJ
>Hi Allen,
Great idea, I'm going to do the same. On the subject of the PC 7 that you used, I'm wondering if that would work for attaching HSS cutters to mild steel rather than braising. I'm talking about a butt joint, not the attachment where you bore the steel and insert the cutter, often using CA. I'm referring to 3/16" for small hollowing tools, not something large where greater stress may be introduced.
Your thoughts?
Mike
Gil Jones on Lake Seminole GA
>Looks like a fine idea, Al, thanks for the pics. Did you mill a grove for the rod to sit in?
Gil
>Mike I have a fair amount of experience with JB weld and PC7 and I don't think either one will work for very long in the mannor you want to glue. To really bond they need a textured surface and both are subject to heat damage althought the high heat JB weld does pretty good. If you could wrap the epoxy around the piece it would do better but it just doesn't glue to flat surfaces together strong enough to hold a cutter.
The PC7 is amazing stuff. We used to glue rocks to a wall to create a climbing wall. You could stand on the stuff. When you get down to something as small as a 3/16 glue area I don't think it will hold. I could be wrong.
Barbara Gill, Remlik VA
>That looks like a great idea Allen but you went and got black stuff all over your white tool rest.:-)
Thanks for answering
>Hi John,
That was my fear but I wasn't sure. I'm thinking of trying silver solder with MAPP gas but wonder if applying that amount of heat for the time required will affect the steel. I don't have welding or braising equipment. In the past I've drilled rod to hold cutters with CA and then bent the rod. I'd like to cut square rod on a diagonal and then attach the cutter to that via the silver solder.
Mike
Re: Butt joining cutters?
Allen Neighbors
>Hi, Mike, thanks for posting. I'd be leery of trying to butt join a cutter with it. Even a 3/16" cutter. I would drill a hole and use a 1/4 x 20 set screw to hold it.
In the PC advertisement, they have a 3/4" x 3" x 3" board butt joined to the side of a soda bottle, with a dowel pin glued on as an angle brace. A clerk that weighed 225 lbs stood on it, so it is certainly strong, but I don't think it would hold a cutter with all the stress. You might try it, but be sure and wear your safety gear.
I attached two 5/16" nuts to the top of my D handle on my hollowing rig, and tightening the set screws caused one of them to give way... but that possibly could have been caused by my not cleaning the square tubing enough. I ended up brazing the nuts on.
If you try it, let us know if it works, though, it would save some folks who can't braze (sp), some money for labor. :)
Allen Neighbors
>Thanks, George, I appreciate your kind comments. I really enjoy trying to do some things myself, that makes turning easier for me. Most of the time, I'm trying to save a little work, and a penny or two.
Before I do the last toolrest (the one for the outboard turning, I'm going to try to temper the piece of rod in my oven. I was using my old Craftsman parting tool this afternoon, and got a small nick in the 12 inch rest, when I had a small catch. The edges of the parting tool weren't rounded very well up close to the handle, and it's really getting short. So maybe we need to temper them?
Whatever you do, thanks again for the comments, and I hope it works well for you.
Allen Neighbors
>Thanks tm, How are you getting along? Did you get everything finished in your shop that you were doing?
If you use the 0-1 drill rod, you might try tempering it a little, in your oven, because I got a nick in mine during a small catch when parting off. I was using an old Craftsman parting tool, and it wasn't rounded up near the handle. (It's too short to really be using.) I'm going to temper the last piece before I put it on the other toolrest, and see how that does.
October is the turning symposium in Wichita Falls. Still thinking about it?
Allen Neighbors
>I used my 80 grit 6X48 belt sander to flatten the edge. Then used my Dremel to make a slight depression for the rod to lay in. Then I scored the bottom of the rod on the same sanding belt, to give the PC7 a little 'tooth'.
Thanks, Gil.
Allen Neighbors
>Yep. Black stuff smeared all over... but a little white rustoleum should take care of that... if I cared that much about the beauty of it. :) Wonder if Oneway has some touch-up paint for sale?
Probably not
>Hi Allen,
I've done the cutter in the hole method and that's fine. This time I want to apply the cutter to the end of square (same dimension as the cutter) steel.Bob Rosand was at my shop the other day, he makes small hollowing tools using the same material and braises the tips. (With square stock, there's less tendency for the tool to roll while cutting). Not having that capability and reading your post got me to thinking about trying the epoxy. I'll probably try silver soldering but I may epoxy one just for the heck of it and give it a whirl. I'll let you know.
By the way, on small tools, I CA the cuttersinto the hole. On my homemade 3/4" boring bar, I use a set screw.
By the way
>Have you thought about using HSS rod for the toolrests rather than the O1? I buy the 1/4" and 5/16" from Enco in various lengths for making small skews and detail tools, I know they supply it in lengths to at least 8".
Mike
Re: Probably not
>Mike I've made several of the Bob Rosand style tools however I always make an L shaped place for the bit to go. This gives much more strength to the joint. I don't know how well a butt joint would hold up. If you wanted it to be a square to square joint I would make a small rabbit on both the HSS and the shaft. This woiuld make the joint much stronger.
Re: Probably not
Allen Neighbors
>Okay, Mike, I understand, now. :)
