CA Glue on Glasses?
CA Glue on Glasses?
CA Glue on Glasses?
david
>If you are like me, at one time or another you may have set the lathe spinning with CA glue on your piece not quite dry, and the CA glue spinning off the piece may have landed on your glasses. I mentioned to my friend glueing my fingers together and the burn I felt when the CA glue went off. Man, did it sting! Then I mentioned sanding off the stuff from my fingers after it dried. My friend said he soaked his fingers in water until the glue lost its hold and cleaned off the glue on his hands that way. A few days ago I got a spot flung on one of the plastic lenses of my glasses. The last time this happended I asked my optician and they said they could not clean off the CA spots. Last night I soaked the side with the glue on the lens in a glass of water before I went to bed. This morning I was able to rub off the spot of glue, about 1/8" in diameter. Clean lenses again. Problem solved!
Re: CA Glue on Glasses?
Andy DiPietro
Use Debonder on Hands *LINK*
Andy DiPietro
>it works in seconds. I keep a bottle next to my CA glue. I have not tried it on glasses since most glasses are plastic and I do not know how the bonder will react with plastic. I have small specs of CA glue on my plastic lenses, so I will try soaking them overnight in water.
Thanks for posting.
Andy D.
http://www.grizzly.com/products/h0929
Mike Rubes, Apex, NC
>Hi David,
That is very good to know about the water! I got a drop of CA on my glasses about a year ago and ended up with new lenses. The guy at the glasses store said they couldn't buff it out or get it off in any way.
It's bound to happen again :) and next time I'll try the soak.
Thanks,
Mike
Allen Neighbors
>I had CA and other stuff on my glasses. I took them to the Optometrist where I got them. He took down a can of Acetone, and cleaned them. Now I use Acetone on them a couple of times a week.
My lenses are plastic, and the type that darken when I go out into the sun, but they are the kind you can shoot with a pellet gun and it won't go through... they'll break at the point of impact, but the pellet won't make a hole.
I tried the Acetone on my Face Shield, and ruined it; had to go get a new shield for it.
Wally Dickerman in Arizona
>I use de-bonder which can be had at Craft Supplies and other wood stores. I've used it on my safety glasses many times. Works well to remove glue from my fingers also.
Wally
Leo Van Der Loo
It's one of the reasons why I have glass lenses,
Leo Van Der Loo
>they also don't scratch as easily as plastic ones, even when those have a coating on.
The glass is impact resistant and CA is easily removed, and yes they are a little heavier, and a bit more expensive to make I think.
>I chewed the CA off my glasses. Just carefully used my teeth to scrap it of. Any port in a storm. I will soak them next time.
Tommy Holmes
>Thanks for the chuckle. When in the field improvise!
Re: Here's the secret for CA on....
Jamie Donaldson
>....glasses,faceshields,etc. Mist a soft clean cloth with Armor All, allow the propellant to evaporate, then clean the lenses. It doesn't remove the specks, but makes them more easily removed next time. I learned this secret from another camera repairman many years ago, and it cleans without leaving a refractive film and works well for a world of objects, including removing fingerprint from my turnings when I visit my gallery outlets.
Glass glasses
Jorge Castaneda
>Hi,
I refuse to use plastic glasses, I work with wood all day and in my spare time I play with wood, needless to say, there is always saw dust in them and I must wipe them at least a dozen times every day, so plastic is very short lived with me. I use OSHA certified prescription glasses, and yes I had a couple times a spot of CA on them, as soon as it is hard, a sharp razor blade removes it, back to normal in two seconds.
Weight is a big factor...
david
>In the choice of lenses for me, because with a strong prescription, the glass lenses end up like Coke bottles and the weight can be overbearing, not to mention slipping down on the bridge of the nose aided by perspiration. The new type of plastic lenses are thinner and extremely light compared to the earlier glass ones. Scratches are a problem but as I get older, I need new prescriptions more often any way...Have you noticed that the CA glue that flies on your lenses always are nice and round? You'd think that they would splat or something!
I realize that I don't have this problem
Bill Howatt
>with my glasses because anytime I am near my spinning lathe I have a faceshield on. I bet the stuff really stings if you don't wear glasses and get it right on your eyeball. Use a faceshield.
Bill
Re: Weight is a big factor...
Jorge Castaneda
>David,
Yes I know they weight more, when first got them 1994, had to use a strap on the back of my head to prevent them sliding down the nose, I don't know how, but after a while they just stayed put and I need no strap, I got a hit by a knot thrown by the table saw, man! I was glad I had those glasses on, nothing happened to me or the glasses.
Yes! Isn't that something? they are perfectly round, maybe because they were turned ;o))
