removing scroll chuck
Ken Kimura
>I attempted to remove a nova scroll chuck from my Sears 103.23870 Dunlop Lathe by engaging the index pin to hold the lathe spindle and sheared the pin off. What direction was I supposed to turn the scroll chuck - clockwise or counter clockwise? Any ideas for holding the spindle while I remove my chuck? Thanks. Ken
Re: removing scroll chuck
david
>Ken: If I am not mistaken, removal should be turning in the counter-clockwise direction. That's the way its been in the two lathes that I've owned. Not familiar with your lathe, but there could be a couple of options for holding the spindle in place. If you have a handwheel, you can place a wooden wedge between the wheel flange and the headstock housing. There may be a sight hole in the housing to view the indexing pulley, and there may be some opportunities there. If you are having trouble getting the chuck off the spindle drive, (for next time) others have placeed a nylon washer between the chuck and the headstock. Good luck getting your chuck off.
Bill Hale / The Wood Spinner
>First be sure your lathe does not have a spindle locking devise. If it does, use it for step one
On the outboard side. block the spindle so it will not turn. Be sure to set this up so you can get to the hole in the chuck for next step.
Inboard Apply a little WD40 or = to the threads on the chuck. In an hour or so insert a bar into the hole in the chuck and hit the bar with a hammer. Don't be to gentel, a hard quick wrap should do it.
After you get it off clean the threads on the spindle and the chuck and apply a little WD40. This should prevent lock up. Also remember when you put it on you don't have to get more than just tight.
Good luck
Bill in Casa Grande, AZ.
Bruce in Saint John N.B.
>Look and see if there are machined flats on the headstock spindle, some manufacturers machine flats on either side of the shaft where the drive pulley is mounted. This lets you place an open end wrench of the proper size on the flats so you can hold the shaft while removing the chuck. Indexing pins are not designed to hold the shaft for chuck removal, most lathes are equiped with a spindle lock which is much stronger and will handle the unlocking stress. The head stock will have right hand threads on the inboard side and left hand threads on the outboard side. In other words if the chuck is on the inboard side of the headstock you will turn the chuck anti clockwise to loosen it, that is if you are viewing the chuck from the jaw end. Oh, almost forgot if there are no machined flats on the shaft perhaps you might be able to told the shaft with a stilson or pipe wrench. The only thing here is the pipe wrench will sometimes mark the shaft with the teeth of its jaws, so be carfull and for heavens sake don't try to hold it in this fashion on the treaded portion of the outboard side as it would damage the threads. After you remove it try and find a nylon, plastic or even a leather washer to use between the shaft and the chuck, it will make it much easier for removal in the future. Hope this helps and also trust I haven't totally confused you, please let us know how you make out.
Bill Howatt
>I always have a thin plastic washer made from a margarine container lid on my spindle. It does a good job to keep chucks and faceplates from getting jammed on too tightly. I drill a hole with a Forstner bit the size of the spindle and then cut around it with a pair of scissors to make the washer.
Bill
Ron in Drums PA
>While that may sound like a good idea, using washers can prevent a chuck from seating exactly the same way each time it's installed on the lathe.
It worked!
Ken Kimura
>I did it! Thanks to all your help. I'm not much with machine terms so RH and LH threads don't register. I opened the jaws and saw a bit of the insert thread. I just used a bent scribe and followed the thread out. Counter clockwise was correct. The outboard side was threaded to the end but the locking nut securing the spindle bearing was exposed enough to put an adjustable wrench on it. I smacked the flat on the Nova insert for good measure and it came right off. Thanks again. Ken
Bill Howatt
>The plastic is very thin and dense. I have measured the runout at the circumference of my Stronghold chuck and it is the same with or without the washer, around 0.001".
Bill
Re: It worked!
Dinyar Chavda
>Ken:
You said "I smacked the flat on the Nova insert for good measure ". That immediately brought to mind all the times when Father James or Brother Michael would smack the flat of the ruler on my palms for good measure. They claimed it worked also!
Re: It worked!
Mike Cunningham (Cape May)
>Sister Florian used the edge of the ruler...........She also used her fist. Both worked.
Mike
>Hi Bill,
I've not measured run out but like you haven't found the washer to create any difficulties. Not only have I been using a washer for several years but as John Lucas suggests I seat the chuck or faceplate by tightening it gently but firmly into place. Nothing has "stuck" since using the washer.
I've also read what Ron suggests, that the use of the washer can cause problems, I just haven't witnessed that.
Mike
