Osage and Lapis "Outlay"
Ed Davidson (Colorado Springs)
>This Osage Orange bowl measures about 8" across and stands 3" tall. The edge treatment is called "outlaying - see the inlay from three sides" and is composed of epoxy and dark blue embossing powder�looks just like lapis stone.
The "outlay" process was developed by Larry Fox, a friend of mine who lives here in Colorado and uses locally mined (Cripple Creek, CO) natural turquoise exclusively on his large outlay-bowls.
Best regards,
Ed D.
Re: Osage and Lapis "Outlay"
Rick D.
>That's a striking edge treatment on my favorite turning wood.
Kinda cool.
But what if the wood moves?
Will the edge restrict movement, flex with movement or (heaven forbid) crack?
Rick
>Thanks Rick... can't say from first hand experience, as I've only been making these style bowls for a couple weeks. But Larry Fox has made hundreds, maybe a thousand or more, and to the best of my knowledge, none of his outlay edge treatments have cracked or broken.
Here's another...maple burl with an Inlace turquoise outlay.
Best regards,
Ed D.
Bill Crommett
>Striking !!
Now that's COOL!
Dominic Greco in Richboro PA
>Ed,
Ever since I started experimenting with Inlace, I've always wondered if I could pull something like this off. Now it looks like you've not only accomplished it, but turned a lovely bowl even more fantastic looking.
I've seen a local turned pull something like this off using clear resin and assorted tiny sea shells. The rim of his bowls are like miniature aquariums. Needless to say, they sell really big down by the sea shore.
Did you turn a recess in the bowl's lip prior to "casting" the resin mix? And I imagine that you could use a MDF mold with a recess slightly larger in diameter and wider than the bowl rim. The mind boggles. I'd love to hear more details about how you did this.
See ya around,
Dominic
Roger in MO
Roger in MO
>Ed, that edge treatment really catches the eye. Like
Dominic, I'd like to learn more of the technique. Aare you willing to share?I like the cutout bottom in your other post also.
>Thanks everyone. I appreciate the comments and encouragement.
The four scallops that turn into feet on the maple bowl were made with an oscillating sander...very carefully.
I need to clarify that the outlay process is not mine to disclose the how-to on...sorry. I can tell you a little more, but probably best to do that off-line. Send me a private email if you'd like some details.
Best regards,
Ed D.
It seems to me that if you
Norm Smith in Nova Scotia
>rough turn a bowl with lots of wood on the lip, let it dry, remount it, true it up, cut a grove in the lip, cut a key in the center of the bottom of the grove, fill with inlace or whatever, let dry and than turn to finish, should work????
I must try that and will post success.
