Re: Polyurethane glue
>Bill,
If it's true waterresistence you seek, consider TB III. Has the same waterproof rating as the poly, but not the history of joint failure. I quit using the monkey stuff after a number of joints in flatwork failed after full year's seasonal changes. Stuff is ok where you've got precisely matching joints, but any small gaps are broken joints waiting to happen.
A good coat of pastewax with be effective in either case. Don't buff the waxed form (leave as much wax in place as you can) and any that transfers to your workpiece will wash right off with naptha after the glue has set.
If you're really concerned about a release agent, put on the wax and then apply several coats one of one of the commercial mold release agents like poly vinyl alcohol.
mm
