200+ woodworking book reviews
Light Tent *LINK*
Light Tent *LINK*
Light Tent *LINK*
Ron in Drums PA
>Small but nice light tent.
Light Tent
Re: Light Tent *LINK*
Seems like a good price...
david
>And the 36" x 36" price is almost half the cost of an EZCube 30" x 30" light tent. May be a case of apples and oranges, but from a price point view, certainly is an option to consider.
Re: Seems like a good price...
MountainMan
>How would you provide a ligfht source? Or is one needed with normal house illumination??
Regards
The MountainMan
It depends.
>Normal house illumination is 2400 degrees kelvin or less. The tungsten setting on your digital is probably 3200 degrees meaning that normal household light will look orange. Some digitals go lower in Auto white balance but most that I've checked don't.
I prefer to use quartz halogen work lights as a main source for illumination. They are around 2700 degrees kelvin but for most people the tungsten setting on your camera will be close enough to give good color with these lights.
If you had all white walls and ceiling you might be able to just bounce the light off the ceiling and not even use a light box. If your walls are colored Iwouldn't do that. Most of the time all that's needed to light a light tent like this is one light, up high and slightly forward so it lights both the top and side panel and some light spills inside to bounce off the other panel. Then you might need a white card or a card with aluminum foil on it to bounce light back into the shadow side of the piece. Most people overlight the pieces and lose the illusion of roundness in the photo.
Re: Anything smaller than 36"x36"...
Jamie Donaldson
>... is too small for most turning photos unless you only do small work like pens. You need enough width in the back to use a seamless background without visable edges, and Q/H shop lights are the best light sources for the money- they meet the Phrugal Photo Studio criteria!
>My homemade light tents are smaller, about 24x24. They only have 2 sides and a top so you can move the background as far back as you need. You need to make your light box appropriate for the size work you do. I just shot some belt buckles and metal boxes that are about the size of Carole's vessels and I used 3 home made panels that were 12" square. I've use these panels either individually or all together to shoot my boxes which are as large as 5" x 8".
I have panels at work up to 4'x6' and they can be ganged to together to make 6x6 foot panels. That's overkill but necessarry for some things.
Most commercial boxes are too limiting because the background is too small behind the piece. They don't do a bad job for jewelry and really small things but I'll agree with jamie. Bigger is better depending on how much room you have to work.
Ron in Drums PA
>I have the small one (12"x24") and a 30"x 30" tent
The small one, which can be used like a long tunnel, works well for the boxes, pens and ornaments I photograph. I set it by a window and use some reflectors for lighting. I can set this up in about 5 minutes or less. I have some studio lights, but most of the time I'm too lazy to set them up.
Besides, I like blue, they are the color of my dungarees.
Re: Dungarees?? I thought they were called ...
Jamie Donaldson
>... jeans, with some color name preceeding??!! ;-)))
Ron in Drums PA
>Showing my age I guess. When I was a kid guys wore dungarees and girls wore jeans. Just like guys wore shirts and girls wore blouses. No big deal really, just the way my brain is wired.
I still can't bring myself to call a hooded sweatshirt a hoodie or walk around a mall with the hood still on my head.
I guess I'm an old fart, I even got my first junk mail from AARP this week. That must count for something.
