Another view #2
C.W.Stivison
Another view #2
C.W.Stivison
Re: Another view #2
John Veerkamp
>CW , nice first bowl. That said I think that it would look much better if the bottom was tucked in/curved in instead of straight down. I know what you mean about learning one thing at a time. I'm lousey at photo's also.
happpy turning,
John
Re: Another view #2
david
>C.W.: Echo John's comments. A lot of what you can do with the bottom of the piece depends on the kind of equipment you have access to. Did you have a faceplace mount? I doubt it, because then you would logically turn the outside first, and it would be easier to form a rounded bottom. There are, of course, many ways to turn a shape, and a lot of the equipment in use today was not in prevalent use say 10 years ago. As you acquire more equipment to get the things you want to accomplish, your shapes will undoubtedly get more refined. Keep up the good work and keep at it.
Re: Another view #2
C.W.Stivison
>David I only have a nova g3 chuck and a Jet mini but I am waiting for the new mini cole jaws to become avalible. Woodcraft says it will the first of April before they arrive. Hopefully that will help with the bottoms. Also we have a turner comming to our May meeting to demonstrate vacum (sp)chucks so that may be another option I will try.
Thanks
CW
you can do this without cole jaws
steve antonucci
>I used my chuck to turn a "flat disk" with a chuck hold on the back from two small pieces of MDF glued to make it double thick. The chuck means you don't need to retrue it every time you use it.
Take the disk in your chuck and round it and face it so it runs true. Then cut steps 1/4" deep from the inside or outside (I've done both). You can use this to center your bowl on the headstock, and then bring the tailstock up for support. Very little pressure required. Then you cut the bottom down to within 1/4" of complete and clean it up with a chisel and some hand sanding.
Hope this makes sense.
Steve
Back in the USA!
Re: Another view #2
George Van
>C.W., when you have turned the outside and installed the tenon and after reversing and mounting the bowl on the tenon to finish the inside, and having completed the sanding, you can again reverse the bowl against something as simple as a block of wood held in your chuck that you have rounded to break the rough edges (keep it from marking the sanded bowl interior), cover the block of wood with something soft like a piece of sponge or mouse pad, carpet backing, etc. and apply pressure with the tailstock, you should have the mark that was left from the live center to help you re-orientate the bowl so it spins rather centered once again. Now you can turn the bottom of the bowl to the shape you wish except for the little pip where the live center is pushing. When you are satisfied with the shape, sand the area you changed to blend to the bowl side and take the bowl off the lathe. You can now cut the pip off the bottom (do not break, it may pull fiber from the bowl and leave an ugly hole) with a saw or chisel and blend that little area with sandpaper. You are now done except for finishing. This is quicker than it takes to type in my find and pick style. I have a vacuum chuck and still use this method when I do not want to get the vacuum out for one bowl.
Re: What George said
david
>George gives good advice here. The operative phrase is when reversing the form on the lathe is "relatively centered". You can work for several minutes moving the piece back and forth to get it centered, and still not succeed. This centering does not have to be perfect.
