Have a question? Ask Woody!
Crack Filler Question?
Andy DiPietro
Andy DiPietro
>Hi Everyone,
From the picture you can see that I have a nasty crack in my black walnut hollow form. I would like to fill it with epoxy with some type of dark filler. I could use some finely ground coffee grinds or something better. The crack is 3/32� wide and it is raised 1/16� above the form. The wall thickness is around 1/8�. Suggestions please.
Thanks
Andy DiPietro
Re: Crack Filler Question?
Carbon black w/epoxy works real good
Bart Rhoads
Get a charcoal pencil
Dominic Greco in Richboro PA
>Andy,
When I have a crack that is narrow and coffee grounds are too big, and/or I want filler that is blacker than black, I use a charcoal pencil. I used to sketch quite a bit and have a stash of them out in the shop.
I just sharpen it then rub the tip against a piece of sandpaper. I then use the sandpaper to "funnel" the collected charcoal filings into the crack/recess and add a drop of thin CA glue. I would not suggest using accelerator until the glue is mostly dry. The accelerator tends to cause the CA glue to turn white. Something you don't want to see in the middle of black.
If you have enough room (which it looks like you might not here) you may need to apply tape to the other side of the crack to stop the charcoal dust from dropping right through.
See ya around,
Dominic
Stuart Johnson
>Epoxy with black powdered Rit dye works very well.
Make it a design feature. *LINK*
david
>One option is to put in a couple of butterfly patches and it becomes a design feature. Also a value added item because the crack is recognized and the patch is evidence that the cracking has been addressed. In Hawaii bowls do not diminish in value from the presense of these keyed patches--they sometimes sell for more.
Website below is to show these patches on a piece and not necessarily an endorsement.
Butterfly patches
John Veerkamp
>I like things with natural cracks, but I have had good success with finely ground coffee and thin CA glue. It might take a couple of rounds of filling and sanding to get a nice even fill, but it works well and will be a dark brown, not quite black.
John
Bill Neddow
>I agree with John. That kind of crack, running with the grain, is a natural for filling with coffee grains (the finer the better) and CA glue. It will make a feature out of it by turning it into what appears to be a bark inclusion -- and it will look natural.
Wally Dickerman in Arizona
>Yep...coffee grounds.
Wally
matt overton
>try some of the turquoise powders at Arizona Sillouette. They are great accents
Brass Filings?
Jack Savona
Cyril Griesbach
>While this one might be too wide for this, you could break open a tea bag and use that as well.
Andy DiPietro
Good Suggestions Everyone
Andy DiPietro
>I think the best way for me to resolve this one is to experiment with the cutoffs from the same log that are cracked now. I can try 3 or 4 of suggestions, sand them down and see how it looks.
Thanks
Andy D.
Graphite
Jorge Castaneda
>Andi,
I use graphite powder, just a little bit is all is needed, turns easy and looks good. I got a can from a boat supplies place, is made to go with Goudgeon Bros epoxy, that can looks like a life time supply for around $6.00.
Jorge
Tom Storey
>Watch the thin CA glue!! Chances are very very good you'll put on too much CA and it will run all over your work piece. Terrible stain to sand out of most woods. I've been making that mistake too long!!
I think thick ca or epoxy with an additive, pastel chalk colours, toner from a printer or whatever. Lay in on and rub it into the crack and let it dry. Sand and yer done. If the crack is very thick, try an inlay material.
Tom
tek-Brunswick, Ohio
>Tom. Put a sealer coat of your finish on before you use the ca glue and it will stain much less if at all.
