Outboard turning?
Outboard turning?
Outboard turning?
wilbur
>I have an old Walker Turner lathe, with RH threading on the inboard side of the spindle and LH threading on the outboard side. I thought I would be clever and get an adapter with LH threading so that my chuck could mount on the outboard side. However, the threads that the chuck uses to mount on the adapter are still RH threads.
So am I asking for trouble by mounting the chuck on the outboard side with this arrangement? Is there any way of mounting my chuck on the outboard side safely?
Re: Outboard turning?
>Wilbur Grizzly had some left hand treaded inserts for one of thier faceplates. That may be the way to go. If you use RH threads on the outboard side you would either need a locking set screw on your chuck or a reversible lathe. Otherwise the thing will come unscrewed and fly off the lathe.
spontanious dismount
Rick Allen
>Have you ever seen a workpiece dismount itself off the lathe?
I have and I must say that it's a slow motion catastrophe.
The workpiece is spinning in the direction you expect. In other words there is a LOT of energy in the spinning workpiece. The only thing is that the workpiece is spinning slower than the spindle. You can't touch it to keep it on the spindle because the piece is spinning so fast that you will tear up your hand on the blank you are roughing. You can see the workpiece slowly unwinding from the headstock and there is nothing you can do to stop it. The best you can do is get out of the way.
Once the chuck or faceplate finishes unwinding from the spindle that spinning workpieces is going to start bouncing around the shop. If you turn your back on the dismounting workpiece it could hit you in the head. So you back away thinking that you will be able to see where it is going and you can dodge it. The truth about where it is going and you ability to get out of the way is that you can't see where it is going on the first bounce because it happens way way way to fast. The surface speed is between 20 and 30 MPH. Reaction time is .4 seconds for a sight induced response and slightly faster .35 seconds for a sound induced response. If we do the math we find that at 20MPH the object will travel about 4 feet. So if the spinning hunk of wood first launches itself at you then you need to be 4' away if you are going to see it coming at you. If you are twice that distance then you can perhaps move out of the way.
Of course the spinning hunk of wood can go a lot of different directions than towards you. If you are out of the line of fire then you are less likely to be hit from the first bounce. You can use the lathe as a shield for the first bounce. If you can put the headstock between your head and the spinning wood then the chances of sustaining a life threating head injury goes way down. The second bounce can still get you but chance are good that enough energy has been used in those bounces that threat to live has been replaced by threat to limb. Get to the third or fourth bounce and you are looking at a flesh wound.
The funny thing is that you can work spinning wood for years without a dismount. The conditions for a dismount may be present many many times without anything bad happening. You may think that the whole idea of a dismount is over hyped. If you ever experience a dismount I hope you get the chance to invoke new procedure that eliminates the chance of that type of dismount occurring again.
Rick, you may have missed your calling
david
>You could have been a writer of documentaries! As for the dismount, been there, done that--and almost exactly as you described, only my spinning piece was fortunatelly pretty benign.
Re: spontanious dismount
Robert Henderson
>Fortunately I've never had that happen with a heavy blank in place.
When I first got my lathe (an old 1940s era Craftsman) I left the face plate on the outboard side (These Craftsman lathes have a faceplate that is somehow threaded BOTH RH & LH). I fired up the lathe and watched the faceplate spin off and onto the floor.
wilbur
>So is there a way to avoid this with the setup I have? I double checked my chuck, and it doesn't seem like there's a locking set screw that I can use.
Richard Allen
Richard Allen
>Two options come to mind:
1. Drill and tap holes in the chuck adapter for locking the chuck on the spindle adapter.
2. Get a right hand adapter (insert) for the chuck.
Good Luck and play safe.
