We value your privacy.
Keith Tompkins question on spindle turning techniq
Roger in MO
>Keith, thanks for the post yesterday on cutting beads and coves. I stumbled on to this by trial and error but am having trouble cleaning up the bottom of a cove. I work from both sides toward the middle or bottom. Is it just a matter of practice or am I missing some movement of the tool?
I'll appreciate your comments.
Roger
Re: Keith Tompkins question on spindle turning techniq
>Roger It's difficult to describe cutting a cove in words but I'll give it a try. I start with the spindle gouge with the flute pointing almost sideways toward the middle of the cove. Of course you have to have the bevel pointing exactly where you want the cove to be or it will kick back on you.
As I cut down toward the bottom I rotate the gouge so the flute is up. The problem is the gouge is cutting at a skew angle on the sides and on the bottom gouge is cutting with the wood cutting at 90 degrees to the edge. This is a faster cut but also tears the wood more. What you have to do is slow this part of the cut down or if there is room skew the gouge slightly so the wood is coming at the edge at an angle.
I used to have the same problem and I saw George Hatfield turn a table leg. The whole leg looked like it had been sanded to 600 grit. Even the bottom of the cove. I decided I'd figure out how to do that so I practiced a lot and finally got there.
You will also because you saw the problem and asked the question. That's the first part to improving your technique and that is realizing there is a problem and then trying to solve it.
Keith may have a different approach but I'm sure it will be a good one.
keith tompkins
>Hi Roger, Thanks John, you got it right! If I may add anything, I use a detail gouge, with the wings ground WAY back. This way, I have clearance when approaching the bottom of the cut...only the tip is cutting. Also, be sure the bevel is rubbing the whole while, which gives good control.Having the cutting point right at the centerline helps eliminate the tool spiraling back. Last, by lowering the handle as you approach the bottom of the cove, the tool begins to ride up in the cut..and you can control exactly how much wood is removed.
The real danger is when the tool is rolled over at the bottom of the cut, the side may dig in, causing a big catch. Grinding back the wings, and paying attention at this point helps. With time, the cut will become automatic. This same technique works with the old style continental gouges, but is a bit trickier. Hope this helps.
