Any tricks to using GF Salad Bowl finish?
Mike F
>I do most of my bowls with Watco Danish oil and wax. That finish never gives me trouble.
I'm trying to use General Finishes Salad Bowl finish on some other bowls and am not having very good luck.
It takes longer than the 6-12 hours to dry that the can mentions, 24-36 hours is a better guess. The finish doesn't seem to build up very thick in some places and runs in others. I have bare spots and some drip marks. If I try to buff the piece with 0000 steel wool at the 24 hour mark, sometimes my steel wool gets stuck to the bowl in the partially cured finish (like an insect in amber).
I've tried doing the inside first (over a couple of week period) and then moving to the outside, but this takes forever, is tedious, and the finish still isn't all that nice.
When I attempt to do the bowl all at once, the outside bottom of the bowl gets all nasty, the finish on the bottom never seems to cure, and it creates a general mess.
I place wax paper under my bowls when I am finishing them with this stuff to keep them from sticking to my table. I allow the bowls to dry on this same surface. Is this a good or bad idea?
Do people finish the entire bowl at once, or do you do the inside one week and the outside another?
What temp should I attempt to keep the bowl during the curing process to make this work?
Re: Any tricks to using GF Salad Bowl finish?
david
>I bought a pint from the local Woodcraft store about 3 months ago. Stuff dries in about an hour. Perhaps the product you are using has been on the shelf too long. I applied with a small piece of a clean old towel. Tried a foam brush but that was a disaster--too much liquid in the foam and to difficult to control the flow. Even with the semi-dry towel application, I got some drips. After about 5-6 coats I finished with the Beal 3-buff system. A dazzling gloss finish was the result.
tek-Brunswick, Ohio
>Mike.
Mike I haven't used it for a while, but I got pretty much the same results as Dave did. You could have an old can? I would have the temperature at least 55 or better. High humidity can also slow down drying times. What kind of wood are you using this on? Some types of wood with a lot of oils in them can play havoc with some finishes. I've had trouble with Aromatic Cedar and Cocobolo keeping some finishes from drying. Try thin wiped on layers not thick brushed on coats. If you can't get it to work, try to return it for a new can. General Finishes makes decent products.
Bob Way, Canton, MI
>I like the GF salad bowl finish very much. I had tried applying it with the piece still on the lathe, and with it off the lathe. I can't honestly say I've found the ultimate process, though. My preference is to apply it with the piece still on the lathe.
With the lathe stopped I will wipe on a relatively thin coat. The rag is wet, but not dripping wet if that makes sense. I'll then turn on the lathe at a slow speed and using the same rag "wipe" the surface I'm finishing. It seems to even it out. Problem area is sometimes the center. Ocassionally I'll end up with some streaks or ridges where the finish seems thicker. In those cases I'll use a rag just dampened with the finish to wipe then respin with the same rag. Then I set it aside and walk away. Either headed to bed or off to the day job. It takes that 6-8 hours to dry, and a little longer to actually harden. I do the process over until the finish has the depth and feel that satisfies me.
Mike Brazeau
>I echo what the others have said. I apply first coat generously and wipe immediately followed by thin coats applied with some old T shirt cotton or paper towel and use grey scotch brite or 0000 steel wool in between wiping with a tack cloth lightly. Do a coat in the morning and one at night until I have the build I like. If shop is warm enough and I am not doing anything else requiring the lathe, I leave in the chuck and apply static on the lathe as it is convenient. If cold I apply and then carry in to warmer surroundings. Produces a great shiny finish almost like lacquer on a smooth fine grained wood.
Jorge Castaneda
>Mike,
A day late but here it goes: Last winter I had trouble too, my shop is not heated, so I tried agin in late spring and no trouble at all, and in the summer was even better; for the initial coat I like it 50-50 with naphta, that dries a lot faster and there are no thick spots and no runs, then wait until it is thorougly dry, a day or two,light sanding wit 400 or 600, same 50-50 mix, repeat 4 to 6 times until it is the build up I want, I apply it with a clean rag, old T shirts squares work great. Then I put it away for at least a month, six weeks even better and then wet sand with micro mesh to a dull finish that I like it better than shiny. The end result has absolutely no dust or lint in the finish coat and is a joy to put your hands to it, sometimes I end with a very light coat of Rennaisance wax, lot of stepts and patience but the results are well worth the trouble.
My $0.03 (adjusting for inflation)
Jorge
