ADVERTISE HERE - FREE TRIAL
Ambrosia maple bowl
Ambrosia maple bowl
Ambrosia maple bowl
Pat Taylor
>This is an ambrosia maple bowl I turned with a lot of guidance from a mentor. It's bare wood right now and will get watco and wipe-on poly, but all sanding is complete. 12" diameter, 5.5" tall, 2" base, 3/8" thick.
Comments and critiques solicited...
Re: Ambrosia maple bowl
Ed Moore
>Pat,
The outer shape looks great to me and the sanding looks complete.
You have what looks like a very sharp inner edge. If the bowl is going to be used, then I would find a way to relieve that edge. Round it over or put a small bevel (chamfer) on it. Ask your mentor.
You have not made a "beginner's bowl", with almost vertical sides and a corner. So you have made great strides by simply not doing that. ;^D
Good job.
Ed
Ron in Drums PA
>You did a real nice job Pat.
I have to agree with Ed, the edges need to be round over a bit.
I also like the photography.
david
>Ditto the other comments. This is a nice looking bowl. You mention a 2" base, but the photo does not show wheter the base is a foot or whether the base is a flattened curve to sit on. To my mind a flat area would be preferable to a 2" foot, because when the bowl rocks over a foot, there will be a bump. Just trying to pay attention to the details...
Nice job Pat!!!
dwr
One to be proud of.
Troy German
>Looks great.
Thanks for showing,
Troy
Here you can see the base
Pat Taylor
>It has a VERY slight lift, but definitely not a foot. I'm pretty happy with how the base came out. Thanks.
Re: One to be proud of. *LINK*
Darrell Feltmate
>Nice bowl Pat. The reason the others are mentioning rounding the edge is simply that a bowl in use gets banged. Things hit it on the outside and utensils ding it on the inside. A rounded edge gets dented less than a sharp cornered edge. On the other hand, I like the way the light bounces off the flat surface and sharp edges of your bowl. As with many things in design, compromise is part of the picture.
Around the Woods
George Van
>Very nice form Pat. I agree with the above comments. If this is going to be used for display I would leave the edges as is to get the sharp shadow but you would be disappointed after a few trips to the sink.
Glenn Hodges, Nashville, GA
>Pat your mentor chose the classic form to show off this beautiful wood, nice job.
Pat Taylor
>OK, that makes sense, thanks. I was not planning on using it for anything besides looking at, so I'm not worried abot dinging the corners.
Thanks for the comments everyone!
Jennifer@Indy.USA
>Pat, this bowl is lovely. Beautiful form and I love the simple rim treatment. Nice work!
Jennifer
