Stihl Chainsaw Oiler
Steven Smith
>The oiler on my Stihl chain isn't working. I have taken the bar off and tried to clean out all the saw dust I could find but it still isnt working. Any suggestions short of taking it back to the dealer - its way out of warranty.
Re: Stihl Chainsaw Oiler
Gary in Zirconia, NC
>I also have a Stihl with an oiler that don't work. I was wondering if the filter on the intake hose could be plugged. What are the other possibilities other than it needs a new pump?
Nick Stagg
>I, too, have had this problem. We are lucky to have a great Stihl dealer nearby.. here's what he did:
Empty any residual bar oil and flush/shake/rinse out the resevoir with some mix or gas and if you have compressed air, give it a shot. Most times when we refill there's debri on the cap and some finds it's way into the oil resevoir and plugs the filter. I do this on a regular basis. Hope it helps.
Nick
Roger in MO
Roger in MO
>The suction line on one of mine cracked and it wouldn't pull the oil. You might look for a small hole or crack.
Good luck in solving it. Roger
Steven Smith
>Thanks for the suggestions, I will give them a try.
>Thanks for the suggestions. I gased it and blew it with air and it works now!
