Preserving turning wood
Webster
>I have a few logs that I am going to cut up for turning wood. Only problem is that I am kinda new to the turning thing and once i get the chunks of wood cut up, how do i preserve it, wax? what other preserving chemicals do i have to choose from. How about a whole log? I got one response from another post and just wanted to know if anyone had any other ideas that work well. Thanks
Re: Preserving turning wood
One new option... *LINK*
david
>This material is relatively new on the market. Our woodturning club is getting a short introduction to this product next meeeting from someone recently appointed area distributor of the product. Information learned so far is that this product for woodturners will become the hottest thing for since sliced bread. Product made in Texas, I believe. Interested to hear of anyone's experiences with this product.
Cedartreat Website
Bill Hale / Woodspinner
>I have almost come to the conclusion that trying to save wood in the rough is not worth the effort, at least where I live.
In my humble opinion, when you get it cut it to workable sizes and rough out the bowl etc. and set the roughouts aside to cure. Cure in the shade, and covered with some type of waterproof tarp etc.. Controll the amount of air to prompt a slow gentle cure. Here in the desert I have to put the rough out pieces in tubs with covers and vent them daily for 8 to 12 weeks.
Tell us where you live and I am sure someone from your area will chime in with better info.
Good turning and be safe
Bill in Casa Grande, AZ.
Bill Howatt
>One of the common methods is to cut the log into the pieces and then coat the end-grain with Anchorseal which is a water-based, waxy emulsion. If you are making traditional bowl blanks cut the log about 4" longer than the diameter so you have a bit for small cracks if they occur on the end. The center pith should be removed since this is stress area prone to cause cracking.
Keep the sealed blanks outside or in an unheated garage. Fast drying is the cause of cracking. Leave the bark on since it slows the rate of drying through the side grain (it is already much slower than the end-grain drying). You should plan on roughing the blanks sooner than later since even with sealing they still can crack.
Bill
Re: Preserving turning wood *LINK*
Steve Russell
>Hello Webster,
You need to treat the cut ends of your wood as soon as possible with a wax emulsion sealer. I wrote an article on how to use and apply wax emulsions properly. Point your browser to the following link. Thanks and best wishes to you and yours!
P.S. While you're there, take a look at the article on air drying green wood with wax emulsions in the main library. It contains lots of good information on drying green wood.
Using and Applying Wax Emulsions
Jim King
>If you have a home vacum food packaging machine you can soak the blanks in chlorine before vacum packing. Whenever you are ready just unpackage and rough turn and use Steve Russells boiling procedure. Excellent results.
C.W.Stivison
>Very good information at this link.
Thanks Steve I learned alot.
Re: One new option...
RevDoug
>David, I, for one, want to hear more once you've seen some of what they are showing.
Turn 'em round,
Sealing in plastic
Jack Savona
>Jim, that's helpful to know about the bleach. Normally I Anchorseal the sides of the blanks, but about 9 months ago I had tried using Glad Press 'n Seal Wrap (makes quite a seal) on some blanks. A few started to get moldy; others didn't. I think I'll try some with bleach first. Maybe even try a few with Lysol sprayed on. Will report any results.
Jack
Gary Evans Tallassee, TN
>Hi David,
This stuff may be the next best thing since sliced bread, but it seems to me to be way overpriced. $40/gal plus shipping for a 5 gal container when I can get AnchorSeal for around $10/gal delivered in a 5 gal container. AnchorSeal may be a little more than that now. I haven't bought any in awhile. That price point is way too high for me to even consider experimenting with it, and protecting turning blanks is part of what I do.
Also, it gripes me to see someone taking a right action (using environmentally friendly ingredients) for "politically correct" reasons. Protecting the environment is not political correctness, it's the only sane course of action. We only have one planet. If we futz it up completely, what will we do then?
Gary
Re: Sealing in plastic
Jim King
>Jack: Dont be bashful with the bleach. Most of the woods we work with are acidic in the first place and I dont know about woods up there. We bag them soaking wet direct from the chlorine dip and in a day or two they look dry in the bag.
Stuart Johnson
>It appears this is a stabilizer like Nelsonite or Poly2000 not a product like Anchor Seal. We have used CedarCide for insect control in the past but it is not always available. It works on fire ants but does take longer.
Personally I don't care if a product is good for the environment because the manufacture wants to be P.C. or because they are concerned about the environment. The result is the same.
Russ Fairfield
>A lot of what you can get away with for the care and keeping of wood will depend on the temperatures and humidity of where you live. I can share several things that have worked for me, regardless of the climate.
What you do with the wood now will depend on what you want to do with it later.
1. The closer the wet wood is cut to being ready to put in the lathe and turn, the better it will keep, regardless of what else you do with it. A rough turned bowl is best, and a lathe-ready round is just as good provided that you also do #2 and #3.
2. Do something to slow the rate of evaporation from the wood surface. Hot wax is excellent, so is AnchorSeal, liquid-nails adhesive is good and sometimes can be cheaper than Anchor-Seal by the gallon, latex paint works fairly well, closed cardboard packing boxes work, and wrapping in old newspaper is better than nothing.
3. Store it in the coolest place on your property, and out of direct sunlight. Avoid moving air and wind.
4. Store it in a sealed plastic bag or other container, and you have sealed it in its environment. It will not dry. What it will do is spalt and then rot, and that will take from 6-months to 2 years, depending on species and temperature.
5. Do nothing and the wood will dry and become firewood in a year, 2-years max., no matter where you live.
6. Dry firewood can be a good turning wood, but there will be a lot of wasted wood, and fewer things you can do with what is left.
Re: Price points for the.......
Jamie Donaldson
>... PC environmentally friendly products are ofter set at a premium to give them validity as a feel good endeavor. Seldom do the contents require such a price, but few consumers give them credibility without the price to justify the attention.
>I agree, Stuart, that this appears to be some type of stabilizer. Unfortunately, they seem to be making claims that go against everything I know about drying wood, and I've been studying that subject for more than 20 years.
My understanding is that no liquid is going to penetrate the wood cells more than a few millimeters unless that liquid is introduced under pressure (positive or negative.) I don't think that immersion "until the bubbles stop" is sufficient time to impregnate a green 4" or 5" blank with enough stabilizer to turn the finished piece "from start to finish."
Now, if they are talking about rough-turned blanks, what they say could be valid. It would depend on the thickness of the rough turning and the porosity of the wood.
I apologize for being so sceptical, but I've seen a lot of snake-oil salesmen over the years. When someone claims that have a "panacea", I guess I need to be shown, and I'm not even from Missouri. 8^]
Also, on re-reading, it does seem that this company has a reputation for environmental consciousness. I guess I am just too sensitive to the use of "politically correct."
Gary
>Hi Jamie,
I agree with your proposition, but if that actually is the reason they set their prices as they did, it just gives me one more reason not to try their product.
Gary
Joe Donohue
>Russ, your advice is always enlightening. I am rather new to this board and I have a follow on question for you.
I am a woodturner living in the Reno NV area (very dry). I make a lot of hollow forms and when I can get some green wood to turn I face a puzzle:
I can't really completely rough turn a larger vessel because I need to leave some "beef" at the foot end (which is rather small) to provide stability fror turning at the neck area. Typically I turn the outside about half way down...maybe just past the widest point, then finish turn the inside top half before finishing up by turning the rest of the outside and the inside.
How would you suggest I rough turn these pieces for coating with a wax emulsion?
Joe Donohue
