Spalted Birch Bowl
Spalted Birch Bowl
Spalted Birch Bowl
Ronny Eelen (Belgium)
>Hi,
Some more old spalted birch I had in the pile. It is 19cm wide and 15 cm tall. Things were going fine until I stated taking it off. I somehow messed up the lower curve and as I was parting if off, it smacked against the toolrest which made a few big scratches.
Hopefully better luck next time.
Anyway, any comments are most welcome.
Ronny
Re: Spalted Birch Bowl
Wally Dickerman in Arizona
>Ronnie, I like the second bowl a lot, A very nice classic form. The first bowl needs more curve. The flat area along the middle portion isn't as attractive as a nice curve sweeping up all the way from the foot would be. In my opinion, a curved surface is almost always more attractive than a flat surface.
Wally
Bob Moffett
Bob Moffett
>I think the shape is nice and the grain pattern is really nice. It might be interesting if you took the knot at the top out, sanded around the hole to make ths sides of the hole smooth and left it open there. And then again, someone else might not like features like that and you would want to keep the knot. The knot will probably develop cracks.
Cut it off below that knot...
david
>and it will look like a very good Hawaiian calabash shape. Nothing wrong with that...;-).
>Thanks for the input. I will certainly keep those thing in mind for the next ones. But since this one is kind of ruined anyway (big scratches, wrong lower curve, foot almost sanded away and not flat anymore) I will not change it.
< I had a com-ment from Wal-ly, I had a com-ment from Wal-ly... ....> :-)))
