Brushed Ash Vessel
Brushed Ash Vessel
Brushed Ash Vessel
Bruce Forrest
>This is an ash vessel which measures 7 1/4 inches tall. It was hollowed, fluted and then textured with a steel brush. I've been told that it resembles a butternut squash. I have noticed that people seem to want to pick it up. Any comments welcome.
Re: Brushed Ash Vessel
Dennis Yoder
>I could see why someone would like to hold it. Great use of grain and form. Dennis Y
Don Emmerling
>That is a very impressive piece. Could you describe in more detail the fluting process. I would be very interested in trying to duplicate that style in some of my work. Again a very special piece and workmanship.
Don in Johnstown, Ohio
>I like that "unpolished" look. It has a very organic quality that is very appealing. Well done.
Tom
Beautiful!
Ruth Niles
Bruce Forrest
>The fluting process is the same as my previous posts. I start off with the piece mounted on the lathe and use a router and the lathe's indexing to get things started. The router (laminate trimmer) is mounted on a sled at the midpoint height. It slides on a table (piece of 3/4 inch plywood) which is bolted to the ways. Anyway, the piece is routed which positions the flutes. Then I use a microplane rasp and other rasps to finish the flutes. Sometimes a Dremel is helful as well. Then it's power sanding with the lathe off. Then I part off and finish the bottom. At this point, I would either hand sand and dye,lime etc, or in this case, power brush etc. Hope this helps.
Bruce
Bob Moffett
Bob Moffett
>Very Nice piece. I like the fluting. Would you post a picture of your router sled jig mounted on the lathe? Did you do any of the fluting while the wood was green and did you wait until it was dry?
Allen Neighbors
>I like this piece. It looks almost as if it's done by hand without use of a lathe. The power brushing really applied some neat texturing, which also makes it look older than it is. Good job.
BTW, it's not gourd shaped as is a Butternut Squash. This looks more like the shape of the Acorn Squash.
Well done piece. Yeah, I can see why people want to pick it up, too.
Bruce Forrest
>Of course! You're right. Acorn Squash.
Holy cow Bruce!
Dominic Greco in Richboro PA
>Man, you did a wonderful job on this! The grain alignment is perfect! Not to mention the overall shape. When I opened up this thread and saw the picture, I was totally blown away.
See ya around,
Dominic
Have you considered...
david
>a wavy top profile that would echo the waving grain that is at the top of the piece? Beautiful piece as is, by the way--just a consideration, since you asked...
Mike Rubes, Apex, NC
>Hi Bruce,
Wonderful piece! I reall like this one a lot. The photography is also really top notch.
The grain alignment is really outstanding as well. Overall just a great piece.
Thanks for the pic,
Mike
Ummmm, fried squash is very tasty in Apex, NC!!
Re: Have you considered...
Bruce Forrest
>I think I know what you mean. A top which flares out again and is carved to be wavy.--kind of like the top on a sack which is tied closed. I think it'd work better on something that is more "sack-like". Interesting concept.
Mike Cunningham (Cape May NJ)
>Hi Bruce,
I also saw this on AAW and WOW. A truly wonderful piece. I love the shape, grain and texture.
Wonderful!
Mike
Ray Johnson
>Wow! very nice layout of grain, knots, etc.
