Questions, Questions, Questions!
Roger in MO
Roger in MO
>Periodically I see posts and photos that refer to filling voids with turquoise or inlace.
Isn't turquoise a rock? Does it come in a powder or granules or? Is it soft enough to be cut with HS lathe tools? Is CA used to "glue" it in place?
Is inlace a plastic type of material?
And finally, where can these materials be purchased? I have not seen anything in the wood supply catalogues that I am familiar with.
I'll appreciate your sharing. Roger
Re: Questions, Questions, Questions!
Norm Smith in Nova Scotia
>Roger, You can get Inlace from Craft Supply, Turtle Feathers, etc. They sell the mix or stone separate. I believe that their stone is synthetic???? However I use the Inlace product. However,I often use real stone that has a hardness of no more than 3 or 4.
Hope this helps.
Norm
Sam Scalzo
>Roger, you are correct,turquoise is a stone. Very hard on your turning tools but very nice when finished.I grind it to a very fine stone with a piece of pipe and a tamper. I also use inlace.It comes in different colors and much easier to use.Makes a very nice inlay.You can purchase it a Woodcraft or Craft Supply.Hope this helps.
Sam in Tucson
Re: Questions, Questions, Questions! *LINK*
>Roger I buy Inlace from Turtlefeathers. Inlace is an acrylic resin that is similar to Corian except in liquid form. The chips and fillers they sell are all basically plastics except the metal powders.
turquoise is a stone than can be cut with HSS tools. I've only used it once and mixed it with epoxy. I prefer to use the Inlace products. Real Turquoise does have a special color to it that people who know the stone will recognize so if your market demands it I would use that.
http://www.turtlefeathers.com
Terence Rice
>Yes, Turquoise is a stone. Jewelers call it a semiprecious gem stone. I use it by turning the piece and sanding it with the first grit (150 or 220 if I'm having a good day). I crush the turquoise with a steel morter and pestile I made from a piece of pipe and a rod. I then grade it by running it through two sieves, the first uses window screen and the next uses a piece of panty hose. (Being really sure the panty hose are discards will go a long way towards keeping things quiet around the house.) The coarser grit I use in larger gaps and the finest will fill the smallest cracks. I fill the crack with the stone and drip enough than CA on it to saturate the stone. If I have a deep crack to fill I do it in layers so there is not a pocket of loose powder on the bottom. I fill so the stone is slightly proud of the wood and then use 80 grit sandpaper th remove the excess. Then I sand to 1000 - 2000 grit and apply the finish.
Wally Dickerman in Arizona
>Roger, Turquoise is rock and you can't use turning tools on it. I get it in small granules and a more powdered form from Craft Supplies. I mix it with epoxy and apply it to the void with a small artist's spatula. I build it up a little above the surface of the wood. After a drying period I use a right-angle drill and sanding discs. I usually start with 80 grit and sand it down to almost the level of the wood. I finish up with a 320 disc, taking it down to the level of the wood. It sands well with finer grits as you finish sanding the turned piece. I suggest that you obtain some blue glitter from a craft store. Add just a little to put a little sparkle in the mix.
Turquoise sells well here in Arizona.
Wally
David Breth
>I'll say! You've got good access if you're anywhere near Bisbee!
Roger in MO
Roger in MO
>Thanks for the replies. I'll start experimenting after I obtain some supplies.As has been stated many times, a great forum with a great bunch of people. Roger
Re: Roger, I buy turquoise from
Allen Neighbors
>Colbaugh Processing (You can google them) for $15 per pound of floor sweepings. It's unprocessed. I crush it with this crusher a friend made for me. I mix with epoxy, and fill it a little proud. I have HSS cutters that is harder than M2, and that's what I use to cut it after is hardens.
jared
>I bought some of this turquoise on Allens advice and am well satisfied with the stone. Cost is very reasonable compared to everything else i have tried to buy and the shipping was fast. I am going to post some pictures of my inlays on a new thread real soon. My latest gloat is that i stopped in at a fellows place not far from home. He did a lot of stone work, making jewelry etc and I got about 5 pounds of chrysocolla and azurite scraps from him for $15. It is dynamite stuff and will be using some of it soon. Jared
