Re: Consistent Speed and Pressure
Mark Kauder, Phenix City, AL
>You are so right, Stuart. Another factor - the Blade. You could certainly make a segmented bowl using a 24 tooth rip blade, but the joints would not be very good. Even the much praised Forrest WWII is not great for high quality segmented turning.
I have found that blades with 80-100 teeth give the best finish. You would not want to rip with them, and you really would not want to cut much wood over 4" wide and 2" thick, as the blades heat up. My absolute favorite is the full 1/8" thick, Forrest Dura-Line AT. Costs about $150, but the finish it leaves on even soft wood is absolutely glass-like (I have two). There are others that I have that are satisfactory, like the Rigid 90 tooth Ultra Crosscut that you can get at Home Depot for about $70. I have tested a great many from Delta to Forrest to Oldham. I probably have $700 in sawblades for my $125 Craftsman TS.
I also suggest that you do not rush the cutting process. If you push too fast, you can watch the blade wobble from the overload, and that makes for a crummy joint. Slower means more cuts per inch which equals a smoother finish.
Pressure - Alway push with the same pressure in the same direction. If you do not, and you have a problem with the angle, you will not know where to start solving it. My 24 segment sled requires that I push too the left on the toggle handle for 12 segmants, and to the right for 12 segments. The difference in the segments from each direction are almost un-measureable, but doing it this way provides a perfect ring.
Mark
