We value your privacy.
>I had previously rough turned a very large ambrosia maple bowl. I am now ready to finish turning it and am wondering what type of rim works best with a very large bowl (16" diameter, 7" depth). I am thinking that I need a rim that will assist in gripping/lifting the bowl. Any ideas or pictures would be much appreciated.
>Since the bottom of the bowl is larger than the top you should not have any trouble picking it up with two hands. That is not to say you shouldn't use a rim treatment if you want. In my opinion it is not needed for function.
>I am no expert, but I took a class from one (Richard Raffin). On larger bowls he would put a "thumb groove" inside the bowl under the rim. This is very subtle. Much more than it sounds. The bowl would flow upward and outward until the last half inch and then it would flow inward very slightly. The outer surface was unaffected. So if the bowl were 15" inside diameter at the rim, it might be 15 1/16" just down from the rim. Use your thumb, when it feels right, it is right. I personally like for the top surface of the rim to slope inward as if anything that fell on the rim would run back into the bowl and not outward. You can also put a bead or other treatment on the exterior, but my "Engineering Brain" almost always sees them as decorations and distractions.
>Maybe I just don't understand the question. If I was going to pick up a 16" bowl full of something I wouldn't use the rim. I would put one hand on either side down near the bottom and lift.
>I just thought the bowl would feel more comfortable in my hands if there was some sort of ledge. I like the indentation idea. I'm still playing with things. I will post a picture when I have completed the bowl. Thanks for the thoughts.
>A gentle undercut is a very nice touch -- I usually do this with a few light passes with a sharp round nosed scraper, as the outermost cut will want to be outward, toward the rim to get the cleanest cut. If you make the undercut coming in from the top of the bowl, you'll probably need to do more sanding.
I like to flare the outer profile just a bit, too, with a rounded and angled rim between the two.
