When a bowl becomes a plate?
Jorge Castaneda
>Below there is a thread about when a bowl becomes a hollow form, and some of us are getting into that kind of head, lets continue that discussion here, but going in the other direction, >When a bowl becames a plate or platter?
Thanks
Jorge
Re: When a bowl becomes a plate?
Carole Valentine
>It's whatever the person who made it wants to call it. ;)))
eaglesc
>Isn't everything relative?
I use a serving BOWL for a spaghetti plate.
I also use the same serving BOWL as a soup bowl for stew or Chili.
(BTW the bowl is ceramic and holds soups therefore not an "objet d'arte")
>The way you can tell definitively is:
You are at the wedding reception and you have picked up the bowl?plate and filled it with heavy hors d'oerves in one hand and you have your drink in the other. Now, since there is no place to set either of them down, at the exact moment the little baloney roll-ups fall off, its a plate.
Carole"s got the answer!
David
Ed Heuslein
>Similar question: What's the difference between a bowl and a platter. My answer is, if you don't know the difference, it becomes a "blatter".
Re: A bowl becomes a plate when .....
Jamie Donaldson
>.. the inside of the bowl you're turning becomes larger in diameter than the outside!
