More Tapered Rings
Malcolm Tibbetts
>I just viewed Bill Youngblood�s piece (posted below) and I thought that I�d share another example of my �tapered ring� technique. This piece was initially assembled with double-sided tape into a series of 10� long cones. The outsides were turned smooth and the insides were turned to consistent wall thickness. Then the rings were passed through a drum sander at an angle on both sides in order to create tapered rings. The final glued assembly was sanded inside as it was put together and the outside was �smoothed� after assembly. The title, �Gabriel�s Dilemma� is open to your own interpretation.
