Veritas - Innovation in Tools
Photo Backdrops?
Photo Backdrops?
Photo Backdrops?
Greg Haugen
>I have a "light tent" that is rather large, 28" cube. I also did have some nice back drops that were given to me until my middle daughter wanted something to color on. ARGH!!!
What is a good source for backdrops? Maybe white, gray, or blue-just kidding Jamie :-))
Thanks
Greg
Re: Photo Backdrops?
George Van
>Good question Greg, I will be following the suggestions also. I use a grey vynil window shade as suggested by Jamie Donaldson. My problem is that it wrinkles easily. Don't try to iron the wrinkles away #!*!
Re: Photo Backdrops? *LINK*
>That's the problem we have with window shades. We use them to shoot passport photos.
You can get all sorts of backgrounds from www.porters.com It's hard to beat the seamless paper backgrounds.
http://www.porters.com
Ken Grunke from SW WI
>I use vinyl poster stock, but don't ask me where to get the stuff as I'm using the back of a poster I salvaged.
This stuff is washable, so it's great where kids are around. It doesn't wrinkle if you keep it rolled up when not being used.
Greg, if I remember I'll bring my backdrop to the meeting, so you can take a look at it. It's a poster from Organic Valley Corp., 34" wide and 42" long which is not all that big but good enough for most of the stuff I do.
I like using pure white, as you can get any shade you want by controlling your light placement.
Another possibility: about a year ago I was in Menard's (one of our local building-supply outfits) and saw 4 x 8 sheets of thin vinyl wall covering, white, for $12 or so. It was slightly textured on one side, and I think it was smooth on the backside. I'm guessing it was about 1/16" thick, made for gluing on a wall surface. I've been meaning to check that out again, just keep forgetting.
George Van
>John, are the background papers wrinkled quickly, more of a disposable item?
Don in Central Illinois
>At my studio we use large seamelss backgrounds. If you keep them rolled up after each use they will last quite awhile. Once the get wrinkled or dirty, cut 'em off and use the next section.
>Don is accurate. We get a lot of use out of a background before I have to cut it off. The worst thing is moisture. It wrinkles the background so if you store it somewhere dry it will last a very long time.
You an also cut them down if 54" is too wide for you. I just use a handsaw to cut them to shorter widths. They are 12yards long so you have plenty to use up.
>Those do work great as well as Formica or Plastic laminate. The problem with those is storage. I cut the sheets down to 2x4 feet for our uses and it's easier to store these flat behind other things.
david
>How does one get rid of the wrinkles in those fold-em-up light cubes?
Re: The heavier vinyl shades,....
Jamie Donaldson
>...meaning the slightly more expensive models, seldom wrinkle when rolled up, but I want to know where you found a gray one!!!
Re: Don't fold them and they won't wrinkle!
Jamie Donaldson
