cutting tool for dremel
olejon10
>does any one know were i can find a cutter for dremel grinder that i can sharpen bandsaw blades with the ones i have just grind away
olejon10
Re: cutting tool for dremel
Dick Hines
>I am not sure it's worth the time and trouble to sharpen bandsaw blades. Wood Craft sells 105" one for under $15. I buy 4 at a time so It only yakes me a few seconds to have a sharp blade ready to go.
Try one of the burrs sold for chain saw sharpening
Don Henthorn
Use the cutoff disks, they work fine.
Leo Van Der Loo
That's what I use.
Brian Hahn in SW Wisconsin
Ditto
George Van
>I use a cutoff wheel to sharpen but I have to agree with Dick. I can buy my blades for $6 from a local saw sharpening service. I just toss them when they get that dull. I only use these blades for green wood. I'm going to buy another high quality blade for resawing and will never let it touch green wood. This one I might sharpen.
Tritto (That's Triple Ditto!)
steve antonucci
>Steven Russell has shown the world how to successfully sharpen a bandsaw blade using a cutoff wheel on a Dremel. I was surprised at how quickly it goes by and how good the results were.
The cutoff wheel is used on the top of the tooth and not the gullet. I put a small piece of tape on the blade to mark the beginning and probably took 10 minutes on my 142"x 1/2" blade for my Rikon.
Why replace good steel when you can renew it?
Steve
Re: cutting tool for dremel *LINK*
Mike Brazeau
>Lee Valley sell diamond coated cutoff wheels. They are not as fragile as the ceramic grinding disks. I used a right angle adapter on my Dremmel and was really slick. You touch the top or back of the tooth. This particular disk I picked up at a woodworking show from the Bitlady. Lost some set on the blade but have significant more life for roughing blanks.
Lee Valley
Double up on the cutoff disks-lasts longer
David
