Chain Saw Chain Questions
Allen Neighbors
>I have new a 22" Stihl Chainsaw. My chain tightener has reached the end of it's travel, and the chain is loose.
Is there a way I can shorten the chain myself? If so: How do I identify which link to remove?
Re: Chain Saw Chain Questions
Ruth Harding
>Have you pulled out the bar to it's maximum?
Buying the right size chain will be better than having it fly off with a 'poor' fix.
FWIW
r
Bob Fawcett
>Allen,
I am no chainsaw expert, but at this point I would think you reached the end of the chains useful life.
The bar on my saw can move about 1/2". That would take up 1" of slack. If it wears this much, its about worn out, I think.
If the saw is NEW, take it to the dealer for a fix
gil jones
Leo Van Der Loo
Allen I'm no scary cat, but I shudder thinking
Leo Van Der Loo
>what might happen, if the chain does come apart on you, the price of a new chain is NOT worth it.
And yes I would take it to my saw expert, to see if that is all the travel there is in your saw bar.
But once again I strongly advice against shortening the saw chain, this is not a bike chain, or other drive chain, there are seals etc. in there, DON'T do it.
Have fun and take care
Leo Van Der Loo
Re: And it still fits the sprocket?
Al Crandall (N.E. of Indy)
>I would think that a chain which has stretched so much it can't be tightened would have its pitch so out of whack it would not fit the sprocket any more. My Stihl dealer says that if I use multiple chains, I will need a new sprocket before the chains are worn out. No expert here, but I think I'd be looking for a different reason for lack of adjustment than a stretched chain. Maybe packed sawdust is stopping the bar movement short of full travel?
how to shorten a chain *LINK*
Robin Corell in Atascadero, CA
>Most bars have two holes for the tensioner to fit into so that as the chain streatches you can back it off and place the bar in the other hole. you should also ocasionally flip the bar over if it has a hole on the other side to prolong the life of the bar.
Removing or adding chain is pretty much exactly the same as a bicycle chain. The only difference is that if you are adding/replacing a broken tooth you then have to grind it and the raker to match the rest of the chain. most saw shops can do this for a few $$, or at least for a few less $$ than the tools to do it yourself.
Robin Corell
http://store.baileys-online.com/cgi-bin/baileys/1216?mv_session_id=H77AbtfW&product_sku=SBC
Re: Chain Saw Chain Questions *LINK*
Darrell Feltmate
>You likely need to remove a preset tie strap, if two are together on the chain which sometimes happens to get the right length. Or you may have to remove a tie, cutter with their respective drive links and then replace with sufficient tie straps and drive links to get the right length of chain. For that you should have a chain anvil and rivet spinner for your specific brand of chain. Considering that a poor repair job can have a chain come apart and hit assorted parts of the body, I would have a pro repair it. The Stihl folks are great.
Around the Woods
Roger in MO
Roger in MO
>I've had chains shortened by a saw shop many times for a nominal charge. They normally take out a link and a tooth. This puts two adjacent teeth cutting on the same side but I've never noticed that to be a problem.
Maybe I'm missing something but I've never worried about a chain breaking. Unlike a saw blade the chain has little "stored energy"
I may be wrong but then I've never had a chain to break.
Re: Thanks, everyone, I got the
Allen Neighbors
>message. I've taken the long chain off, and checked out the tightening mechanism, and it's alright. Not too gummed up with trash, either. I held it next to my other chain, and it's longer by a link or more. I wonder if they just added an extra tie or link or something to this one. I've put my old chain on, and sharpened it, so I'm back in business. I'll not try to shorten the other one. I'll just toss it, and buy another.
Thanks for the posts! :o)
Do-it-yourself chain shortening
Dave Staeheli
>I take links out of my chains all the time. Don't know where I got it, but is is a chain breaker and rivit spinner that looks a lot like a vise-grip. Usually at least once in the life of a chain, it stretches so much that a link or two has to be removed. I like to pick up a couple of replacement links (you need a new link to rejoin the chain) everytime I pick up a new chain. Any full service chain shop can shorten the chain for a few bucks, but out side of looking to do as much of my own service as I can, it saves a trip to the saw shop (about 45 miles!),
Don't mean to hijack...
Pat Taylor
>But what is the useful life of a chain? I've got a 20" craftsman that I've had about a month, but I've done about 20 hours on it. It seemed to not work too great the last time, the chain seems to heat up quite a bit and get looser, but I'm not sure if it was just because it was a cold day. Do logs freeze? How often to people replace or sharpen chains?
Thanks,
Pat
Re: Don't mean to hijack...
Ruth Harding
>Pat, logs do freeze. I live in the beautiful rain forest of BC and have had a wood buring fireplace for many years. Like most people on the island we buck our own firewood from fallen trees. If I am spending a couple of hours bucking (fir, maple, alder) then I could potentially have sharpened the chain a few times. Depends on the wood. Having said that, I can still get a chain to last me about 3 years. My Husky is self oiling, but if your chain saw isn't you need to oil the chain/bar. You can get a special grease gun from HD/Lowes, etc., that has a spring loaded tip and costs about $6. There is a tiny hole at the tip of the chain and if you put the tip of the gizmo on top of that and pump up and down you will be greasing the chain/bar. Wait until the blue grease comes through the bar to know you have put enough in there.
Also, I clean out the chain saw frequently (take off the smaller part of the casing, clean out all the gunk, turn the bar)all of this should help prolong the life of your chain and saw.
