Re: Should I bring home wood from Hawaii
Brodie Brickey
>One of the turners in our Southern CA club went to Hawaii last month. He did a presentation on bringing wood back. You take your two suitcases with you. One for clothes, one for wood. Double check with the airlines, but each traveler can bring back 50 lbs of luggage. Fill up one suitcase with wood and adjust as needed.
In Hawaii, you may find that they are using different woods for the framing (no Pine). Our member brought back some wood that was used as framing for a window casing that was to us here an exotic and very nice wood. I think he'll get a nice platter out of it. He didn't bring any Koa back, but there are many other exotics over there that aren't as well known. His focus seemed to be more on flat stock than turning squares. (Side Note: in Brazil they use purpleheart as a construction material to our fir.)
On the green wood front, I don't have any detailed information to provide. If you do get a lot of flat stock scrap, the USPS boxes are the way to go for getting them home once you're over the 50 lbs limit for checked baggage.
Have an enjoyable flight and great time over there. It really is a beautiful place, but it sure ain't cheap!
Regard,
Brodie Brickey
