Fluted, dyed, limed ash vessel
Bruce Forrest
>This is an ash vessel which has been turned, routed, shaped, dyed and limed. It measures about 9 3/4 inches tall. It's part of a series of different colors that I've been making. Started out with a plain vessel, then the next one added flutes, and then came the dye and liming. Any and all comments are welcome.
Re: Fluted, dyed, limed ash vessel
Very Cool!!
MIke from St. Clair Shores
>Bruce,
I've been dying some ash bowls different colors then using the liming wax, but none of them looked this good. The fluting looks great. Really nice job, thanks for posting.
Mike
Dale Cook
>This is a very cool piece Bruce. Beautiful work,the form is great and the flutes are what make it special. Thanks for posting this.
explain liming please
Tom Sontag - St. Louis
>I suppose I could look it up somewhere but I felt you would not mind telling us a leeeetle more about this awesome work. I was with you all the way through dying; what does liming do?
Mike Rubes, Apex, NC
>Hi Bruce,
Very, very nice! I like that. Makes me think of a piece of exotic fruit!
Great attention to detail.
I am also curious (like others) about what "liming" means?
Thanks for the pic,
Mike
Liming Wax
>I got my Liming Wax at Woodcraft. Mine is made by Bri Wax. The way I use it is only on open grained wood that has been dyed. Then the Liming wax is applied and it fills the pores and then you buff it off the surface. The grain is then white and the contrast to the color of the piece looks pretty cool. Just like the fluted vase in this post.
Mikw
Bruce Forrest
>I'm aware of two main brands of what's called liming wax. One is Briwax and the other is Liberon. Both are a white pigment in a beeswax base. With woods like oak, ash and I think elm, it's used to fill the pores and show off the grain. Dying a dark color is often used to increase the contrast. Some people use a wire brush to remove some of the soft wood to increase the effect even more.
Once the piece is dyed and sealed, the wax is applied (very sparingly). A little goes a long way. Then some different methods emerge. Some say to leave 5 minutes, others 20 and others longer, but the gist of it is to wipe off the excess and leave it in the pores. Some wipe it off with a coat of clear wax. Others use mineral oil or mineral spirits, some use steel wool, or fine sanding even. Or just plain rub with a soft cloth. Then you can leave as is, coat with clear wax or use a spray on protective coating. It's time to experiment to see what works for you.
Hope this helps. Bruce
Wow!
Ron in Drums PA
>Really Nice Bruce
>Very cool. The grain pattern really plays beautifully with the shape and flutes. Wonderful piece.
Tom
keith zimmerman, Normal, IL
>Would buffing with White Diamond accomplish the same thing? Just curious because using it will turn the grain of walnut white.
keithz
Michael Sinclair in Orkney
>I like that one a lot.I have been playing with some carved pieces, if I could get half as good a result as that I would be well pleased.
Great work
Michael
dtewell
>Just received the Bill Grumbine first video for Christmas. Bill says never to use the white diamond on walnut. The fibers of the wheel are what turns it white and it's almost impossible to get them out. Probably wouldn't look the same.
Bruce Forrest
>I thank everyone for the comments. I'll have to post on this site more often.
Absolutely Beautiful, Bruce!
Ruth Niles
Jennifer@Indy.USA
>Bruce, I saw this over on WOW and loved it there....just as much as I love it here!
Very nice job with the dye and liming...and the carving and turning and everything :)
Jen
