bleeding
bleeding
bleeding
Bill Youngblood
>Hi Gang,
I am a newbie to this site and really enjoy it. I have been one of those "lurkers" until now but thought I better get involved. My immediate problem is the bleeding of Bloodwood into Holly in a segmented piece. I have had the same problem with Padauk. I solved that by not using Padauk anymore. The Bloodwood is not quite as bad but bad enough. Any of you segmenters got any suggestions? Thanks.
Bill
Re: bleeding
Keith Tompkins
Re: bleeding
keith tompkins
>Hi Bill, the solution is simple...Holly is nasty stuff; I suggest you stop using it and ship it to me instead :) A couple of solutions. Spray the whole piece with sanding sealer, then sand. Repeat constantly...the sealer fills the pores. Use sealer to "paint" just the holly, then sand....these should help.
Re: bleeding
Re: bleeding
>Keith is absolutely correct. Sanding sealer works great. It fills the pores somewhat so they are easier to clean out. I put a coat on between each grit when I have woods that really carry over like Paduak, and Osage Orange. It's a pain but it beats the heck of ruining a segmented project.
Re: bleeding
Re: bleeding
Bob Way, Canton, MI
>In addition to the sanding sealer, another option is to blow off the sanding dust with a compressor and an air gun. That will get most of the dust out of the pores. I do that in between each of the sanding grits. Enjoy your turning.
Bob Way
Re: bleeding
Re: bleeding
Dinyar Chavda
>Just a wild guess (as I don't do segmented work), but could the bleeding possibly have something to do with your name? :-)
Re: bleeding
Re: bleeding *LINK*
Mark Kauder, Phenix City, AL
>Bill,
The blowing out is a good suggestion, if you problem is during sanding, and thus obviously a dust problem.
The sanding sealer is ALMOST a complete solution. Here are the issues. It will not help during the initial sanding, because it will be sanded away very quickly - so make sure you blow the dust out often. BUT if your problem with "BLEEDING" is caused when you finish, the problem is the finish solvent leaching the red from Bloodwood or Paduak (both two of my favorites for segmenting - don't throw them out of your color pallet) into the lighter woods. This can be a problem with the sanding sealer as well (Lacquer or Shellac (alchol)) if you lay it on too wet.
Here are the things I do:
1) Blow out the dust regularly at all grit levels - it also make your sandpaper last longer and cools the wood.
2) Don't use a sanding sealer. Sanding sealers are made almost purely so that your sandpaper does not load up. The serates that are added to help that are opaque and can muddy the look of your wood. (thank you, Russ for that) Just look a can so sanding sealer - there is a reason you cannot see the bottom of the can - you are putting that same stuff on the wood.
3) To seal the wood with either regular clear gloss lacquer or Shellac - the the clearest material that you can find. You spend alot of money for that Holly, don't yellow it with your finish (if you are going to do that, use a Soft Maple instead, they will look the same after finishing).
4) Now you can seal the wood two ways. Lacquer - If you spray, spray the first coats very dry - hold the gun/can quite a way away from the wood, so that most of the solvents are gone when it hits the wood. Using Acetone to thin is better since it dries fastest of the lacquer solvents. Apply several of these dry-ish coats, and then get progressivly wetter. The succeding coats of lacquer will melt into the lower ones, w/o adding enough solvent to cause you leaching problems.
5) A somewhat simpler way with Lacquer, but especally with Shellac, is to moisten a clean soft cloth and carefully wipe the sealant on the Holly. After several coats, apply several coats to the adjacent Bloodwood/Paduak. Once dry, flail away with your finish, and you should not have a problem.
I like the spray method, because I regularly have light colored veneers in the mix somewhere, and I might as well seal the whole thing at once. And of course, I spray finish most of my work with Lacquer anyway.
Bill - will I see you in Ohio this year again?
Mark
http://www.markkauder.com
Re: bleeding
Re: bleeding
Bill Youngblood
>Thanks a bunch for all the suggestions. I will definately be trying to save this piece. If I do, I will post it. If not, I will set it on my shelf of rejects to serve as a reminder. Yes Mark, I will see you in Ohio ... Good Lord willing and the creek don't rise. Thanks again all.
Re: bleeding
Re: bleeding
MIke from St. Clair Shores
>Heh Bill I'm glad to see that we got the lurker out of you. How come you didn't just ask me this question last night at our weekly get together? Steve, Ken, Soozy, Joe, George or Myself could have given you a whole bunch of answers. Even though we mostly turn Firewood, we glue some stuff together sometimes.
Seriously. I'm glad to see you on this site. Just look at all the great answers you got for your question. This site has helped so many turners because of the willingness to share.
Mike
