OT coloring concrete
ronnie
>SWMBO does stained glass and she is going to make stepping stones out of concrete with cut glass on top.
She asked me to put white paint in the concrete mix so the stepping stones wouldn't be grey,will this work?
Ronnie
ronnie
Ronnie
Re: OT coloring concrete
>Don�t know about white paint. Would depend on if it were latex or oil based and how much. Not a chemist and don�t play one on TV, but this would be an experiment at best. Lowe�s and maybe the other borgs carry concrete dye, but I don�t know if they have white. Also, you would want to use white sand. Check with a local masonry supply place and or a concrete company (the Ready mix type) and pick their brains.
Bob Fawcett
>Maybe a white grout mix would work?
Mever tried any of this, just an idea.
RevDoug
>There is a concrete dye that is a dry powder. The idea is to sprinkle the powder onto the wet concrete after floating it. The powder will mix with the water that rises to the top and will permanetly dyd the durface of the concrete. Borgs should carry it.
Turn 'em round,
Gary Evans Tallassee, TN
>Ronnie,
I have used the dye powder. I don't think they make one that will turn grey concrete white. Typically, they tend to be earth colors.
If she wants white stepping stones, the best way to do it is to lay her glass in a bed of white thinset which she spreads on top and around the sides of a grey concrete stepping stone. Be sure and use the fortified variety of thinset. It has a latex or acrylic additive that makes it stickier than standard thinset.
Here's a pic of a different kind of cut-glass stepping stone.
Gary
Re: OT coloring concrete *LINK*
david
>Try this site for various information about concrete and concrete finishing.
http://www.concretenetwork.com/stained-concrete/
Concrete Network
ronnie
>Thanks to everyone for the info and ideas.
Ronnie
Clay Foster
>Use white Portland cement. It will make very white concrete.
>Clay, I had forgotten the white portland cement. At least I remembered the white sand. Between the too you would have Really white concrete. You could even use white stones if you felt you must.
