Respirator questions
Ken Grunke from SW WI
>I am looking for a non-powered respirator, and searched the turning archives finding references to the Resp-O-Rator and the North 7700 respirator as being highly recommended.
Breathing through the mouth I think would not be desireable for me, I occasionally am forced to do so because of an intermittent nasal condition (polyps). I get a very dry throat, and it doesn't make my lungs feel very good. My question for those who use this, do the nose clips allow you to breathe comfortably through the nostrils without having to mouth-breathe?
The half-face masks such as the North 7700 are OK, but I wonder if there's something like it that goes over only the nose, leaving the mouth free? Not to smoke a cig, of course (almost 9 months since my last one :)) but I figure it would cut down on the moisture that builds up inside a mask and allow a sip of water once in a while!
Re: Respirator questions
Russ Babbitt Jr.
>A club member had the Resp-o-Rator. Because of the way it works he said it creates a lot of saliva.
Barbara Gill, Remlik VA
>I have used the North 7700 series ever since 1986 in the sawmill and in the shop ever since I have been woodworking. There is a provision for the moisture build-up by using a exhalation valve at the bottom of the mask. The masks are very comfortable in the winter as you breath nice warm air. I use the low profile dust filters in the shop.
Tommy Holmes
>I have a AO Safety 95190 Woodworkers Respirator that I bought it from Amazon for about $15. It has two valves in it to make breathing easier. The cartridges are replaceable. I do get moisture build-up inside but I just wipe it out.
I also bought a Dust Bee Gone but have gone back to the AO. The AO is cooler than the DBG to my surprise.
Barry Scotton
>Ken
I have used the North for couple of years. I wear glasses and have a beard, it works very well for me, no condensation and fits well over the beard.
Regards
Barry Scotton .... on Salt Spring
Re: Something New
>This looks very interesting. Russ, have you tried it?
Has anyone? Please post your impressions!
>Thanks Barbara, I knew you to be a satisfied customer when I dug up the archive posts :)
The drain valve is a good thing, I didn't know about that.
>Yes, I saw that point raised a few times when I searched the archives. I wonder if the nose clips would help alleviate the drooling problem?
Re: Barry, which filters do you use?
Allen Neighbors
>I wear a beard, and glasses. When you said it fits well with your beard it piqued my interest. I found a Website that has the 7700 and a huge amount of different filters... most of them are talking about 'gas'.. I was wondering which filter cartridge do you use for the dust.
Thanks,
Barry Scotton
>Hi Allan
The filter supplied with mine is Part # 7580p100. It seems to keep dust out of my nose and lungs. I purchased this model as it was recommended by several on this forum some 2 years ago.
Regards
Barry
Re: Thanks. :o)
Allen Neighbors
>I also use the North 7700 on Barbara's recommendation. I find it comfortable and effective. I do not have the "winter" cough I usually get. I have been using the activated Charcoal filters in it. It what came in the one I bought. I have spare filters, some for particulates and some combination ones for both fumes and particles. The mask is sort of low profile and fits under my face shield I use for turning. (The Darth Vader look). The activated charcoal is so effective I can�t even smell the walnut or lacquer through it. I have not had the moisture build up, but I do get thirsty because it interferes with sipping the constant glass of iced tea.
Re: Something New
Russ Babbitt Jr.
>No I haven't. I saw it posted elsewhere and it seemed appropriate to post here.
Russ Babbitt Jr.
>The clips are there to force you to breath through your mouth which seems to be the cause for drooling.
Re: Something New
Bruce Wiseman
>I tried it (from Garrett-Wade)and didn't find it much better than the regular masks. It is cooler with the air flow but you also have the battery pack and wire to deal with. To be fair, since I wear glasses, I haven't found anything that covers my nose that still allows a good fit on my glasses. The closest is the Dust-Be-Gone, but it isn't NOSH rated and really doesn't filter all that well. If I need to use anything, I will wear the Triton, helmet and all.
You mileage may vary.
Bob Moffett
Bob Moffett
>I have been using a Resp-o-Rator for about 2 years and really like it. It filters to a much higher level than most filters. You can use it without the nose clip if you just train yourself to breathe through your mouth. I use the nose clip and don't find it a bother. I can also wear a full face shield with the Resp-o-Rator on.
With my recurrent nasal polyps condition, I am used to breathing through the mouth but when I can keep it under control with steroid nasal spray, I'd rather breathe through my nose whenever possible. I originally misunderstood that the nose clips were something that made that possible. I wonder why they can't make a unit that fits on the nose only, leaving the mouth open--err, not OPEN but uncovered. Seems to make the most sense to me.
Bob, and others, what does this respirator feel like in your mouth--is it comfortable? Aside from the often mentioned drooling problem, that is.
Re: Respirator $17.95
Jerry Whitaker
>See source at the bottom of this post
7700 Series Half Mask Respirator
Sizes:
770030S HALF MASK RESPIRATOR SML
770030M HALF MASK RESPIRATOR MED
770030L HALF MASK RESPIRATOR LRG
North 770030: $17.95
Size 770030S HALF MASK RESPIRATOR SML 770030M HALF MASK RESPIRATOR MED 770030L HALF MASK RESPIRATOR LRG In Stock
Silicone face piece material conforms to facial features and doesn't harden with age.
Silicone is easy to clean, durable and resists distortion.
Contoured sealing flange and cradle suspension system eliminates discomfort caused by pressure points on facial nerves.
Nose area design is comfortable and well-fitting.
Minimal dead air space limits re-breathing of exhaled air.
Direct cartridge-to-face piece seal minimizes replacement parts and simplifies maintenance.
The most comfortable and durable half mask available.
Does not interfere with protective eyewear.
Sizes: Small, Medium, and Large.
http://www.library-dust.com/North_7700.htm
Re: Respirator questions *LINK*
Jack Savona
>Ken, I liked the concept of that single filter forced air respirator with the fan and battery pack so much that when I saw it on clearance for $9.99 at Rockler last year, I bought it. Not too bad, but a bit cumbersome with the pack and wire. Then I became concerned about the quality of filtration and after doing research found nothing to assure me it took out the destructive fine dust.
I subsequently discovered...and REALLY like...my 3M 7502 (medium size) half mask respirator. I literally wear it all the time I'm in the shop. What I like is that it works with my beard and glasses (when I take a quick breath, I can feel it seal) and, best of all, because its N-95 filters are very thin and it exhales downward, I can wear it with my faceshield.
Only problem is when my preschool grandkids first saw me with the respirator, faceshield, and radio headset, they must have thought I was a space alien.
3M Half-Facepiece Respirator
How do you determine size on these?
>Thanks for another good recommendation, Jack.
A question for anyone: This 3M unit and the North 7700 both have 3 sizes, how does one know which one if ordering by mail? Is small child-size, or for a small adult? I would want the smallest that can comfortably fit. I don't see any guiding info for either of the units.
The 3M and North are Very Similar.
>When my granddaughter was brought to the sawmill the first time she must have been about 15mos. old. She took one look at the "monster" with the North mask and earmuffs and started crying. I had to quickly say something and take off the mask.
If I remember correctly, the North filters .3 microns at 99% efficiency. The 3M is probably the same.
Re: How do you determine size on these?
Wilford Bickel
>Ken,
Another vote here for the 3M unit. I use it with the organic vapor cartridges topped by the particulate over filter. You are right that they come in adult sizes of small, medium and large. I recommend everyone find a local safety supply store for their first respirator and get them to fit you - even if you have to pay more for the first unit you will come out ahead health wise being properly fitted.
As to the little power unit that Russ posted - this unit is also sold by Rockler. I sent Rockler an email questioning what OSHA, NIOSH specs it met and they answered that it did not meet any specs and they could not tell anyone what micron particle it would filter. When I responded to their email and asked if they had considered their liability for selling a unit such as that they refused to answer me. Buyer beware on that unit!!
Russ Fairfield
>I still think the Dust-B-Gone is the best mask I have ever used. It is comfortable, doesn't fog my galsses, I can talk through it, ansd it is washable. I would answer the question of how effective it is by saying that my test of not being able to blow black gunk into a clean handkerchief after using it.
Re: I was thinking of getting this one... *LINK*
Ronny Eelen (Belgium)
>Trend also has a smaller one, without a face shield.
Since I have a separate face shield already, I was thinking that their AirAce might be a good one.
Does anyone have any experience with this?
And can someone tell me that it looks cool? I need someone to tell me that it looks cool..... to build up the courage to buy it :-)
thanks
Ronny
http://www.trendmachinery.co.uk/airace/
