TURNING ELM
TURNING ELM
TURNING ELM
C.W.Stivison
>My neighbor has a large elm that died last summer. Is it hard to turn or even worth tring to turn. Remember I am a rookie.
Thanks
C.W.
Re: TURNING ELM
Re: TURNING ELM
>Yes, for a lot of reasons. Elm can be beautiful. Has some interesting grain. Try cutting a crotch or the more politcally correct "branch union" and turning it. (This could lead to a long discussion of how to cut the blank ang prepaire it for turning.)
And, any free wood is good wood. You need to practice and free wood is good to practice on. As a bonus, elm can be great. Also, honor the tree. We did elm a great disservice by bringing in the Dutch Elm Desease. Make something nice and give it a second life. I have a cabinet I made of it with book matched crotch wood inthe doors. The only turnign on it is the handle, but I guess that qualifies.
Re: TURNING ELM
Re: TURNING ELM
John Veerkamp
>Elm end grain can be a challange, but as said it is beautiful wood. Lots of interesting grain patterns. It also spalts readily and the black spalting lines add another deminsion of interest.\\I love elm turnings.
go for it
John
Re: TURNING ELM
Roger in MO
Re: TURNING ELM
Roger in MO
>I have some elm burls that work up great. Several pieces are a combination of burl and non burl. I agree--go for it.
Roger
Re: TURNING ELM
Re: TURNING ELM
David Breth
>When I first started turning, I came across some curbside elm and had a go at it. It was very hard, very challenging compared to other wood I had turned at the time. It was green, and I let it warp into interesting shapes. I think it is a cool wood, and basically, any "new" wood you can add to your experience is a very, very good thing!
David B.
Re: TURNING ELM
Re: TURNING ELM
Allen Neighbors
>Beautiful wood. American Elm and Native Elm, both. Turn it, but don't burn it; it stinks when burning.
(Thanks for the hint on the end grain. I'm turning a large vase... endgrain.. outside is turned, will turn inside tomorrow, if it's not too cold.)
Re: TURNING ELM
Leo Van Der Loo
Re: TURNING ELM *LINK*
Leo Van Der Loo
>Hi CW
Elm, yes all Elm wood is good turning wood, always stringy and sometimes hard, the interlocking grain makes for less trouble drying, also makes it tough for those that have split the wood.
The common Elms around here, American Elm(aka white elm) is not very hard, Red Elm (aka slippery elm or soft elm) is even softer, Rock Elm (aka cork elm) is the hardest heaviest and strongest Elm wood (was used to make english navy battle ships for its toughness), also Siberian Elm medium hard and darker wood, there's also Chinese Elm and several other elm species and hybrids.
Look for nice figured wood on the butt end, crotch wood and around the large branch to log union area.
So get it home, seal the cut areas, place it off of the ground, out of the wind and sun, and go to it.
Have fun and take care
Leo Van Der Loo
http://homepage.mac.com/l.vanderloo/PhotoAlbum20.html
Re: TURNING ELM
Steve Kubien
Oh, I can comment on this one!
Steve Kubien
>I just started turning a plate out of elm (grey elm, I think). I am at the sanding stages of the top surface now and it is slow going. Probably should've picked something easier for my second plate but, well, live and learn. It's tough stuff but so beautiful that it is worth it. It won't be my last piece in elm.
Have fun and keep your sharpening set-up handy.
Steve Kubien
Re: TURNING ELM
Mee too!
Jorge Castaneda
>CW
I just went through 5 bowls and a platter, and still have a couple blanks waiting, one of them a large platter.
Rough out your pieces while green, even if the smell bothers you, it is worth the effort, dry elm is just one degree shy of concrete, so you will have to sharpen very often and keep the bite small, I ended up having a spray bottle with water and a light spray before a light cut seems to help a lot. The reward is sometimes a spectacular grain. I still have to finish them, so I cannot help in there, but it has big pores and confused grain amny times.
Go for it
Jorge
Re: TURNING ELM
Re: TURNING ELM
Mike Nelson
>We have Cedar Elm around here, central Tx., I have turned boxes green from four inch straight end grain trunks and had them fit perfectly after finishing. Working on a tall, spalted classical vase now, love this stuff! Leo, have you heard of Cedar Elm or is that just a local name?
Re: TURNING ELM
Leo Van Der Loo
Re: TURNING ELM
Leo Van Der Loo
>Hi Mike.
Yes farther south there are several more species, there's Water Elm (aka planer tree) and some other non flattering names, it's a small Elm, then there is winged Elm (aka Cork Elm or Wahoo), and yes there's also a larger Cedar Elm (aka Basket Elm and Southern Rock Elm),then there's also the European Elms, some of which have been planted in North America, Zelkova not a true Ulmus but closely related also grows in the USA and elsewhere, yes there are enough to get confused, and some are hard to tell apart, but all have good turning wood IMO.
Leo Van Der Loo
Re: TURNING ELM
Peter Charles Fagg (UK)
Re: TURNING ELM
>I feel I must add my 2 cents worth!
Good Elm in the Uk is getting rare which is a pity because it can be really wild grain and give fascinating platters with tight swirling grain patterns.
If it were possible I would turn more and I envy you the possibility of getting some for free.
Regards from one envious UK turner, Peter.
