Shopping for new lathe
Ray Binnicker
>I currently have an older Delta (1950's) and am thinking of upgrading to a new model, one with electronic speed control. I've looked at several models and keep coming back to the Jet 14". It's in my price range, also. It also had some pretty good reviews on Amazon. I see the Grizzly 14 and 16 " for almost half the price of the Jet. What are your opinions on the Jet -vs- Grizzly.
Thanks
Re: Shopping for new lathe
Bruce Wiseman
>Well, I may be way off on this, but I don't think Jet makes a 14 with electronic speed control. The 16x42 has electronic speed but the 14x42 has the reeve pully speed control which is mechanical not electronic. That being said both are fine lathes.
Gordon Seto
>Other than those clones, haven't seen a new lathe model that is still using the Reeves Drive. Now even the entry level mini lathes have Electronic VS rather than mechanical VS.
Grizzly has some good line up on tools. I have some reservation about their lathes. I don't have any high regards for their design. I don't think they are built by engineers knowledgeable of woodturning, for wood turners. Avoid those models that use odd ball size spindles.
I don't even like their latest top of the line G0456. Looking at the picture, it seems Grizzly just adds some bells and whistles to half century old gap bed. I would rather have a hand wheel on the other side of the head stock than a polisher for the callus of my left palm. I also won't want the fine sanding dust so close to the electronic control. For the price, I would choose the Jet 1640 which has proven track record and resale value.
Join a local club, find the opportunity to try before jumping in.
Gordon
>Bruce is correct. The Jet 14 is a Reeves style speed adjustment. Works just fine it's just that you have a lever to adjust the speed with instead of a knob. Every so often you will have to lubricate the sliding pulleys on the drive but other than that it's fine. All the parts are replaceable. With an Electronic speed drive you may have to replace the electronices if you have a serious problem and this can be expensive. On the plus side there have been very few problems with the electronic drives.
As was mentioned above stay away from the odd spindle sizes. 1"x8, 1 1/4" x8 are very common sizes with 1 1/2" x8 being close. Stay away from 1'x12 and 1" by 10. These are odd sizes and it's very hard to buy accessories.
Most people I've talked with who own the higher end Grizzleys have felt they are a good lathe for the money. I haven't met as many people with the lower priced lathes but the ones I did are dissappointed with the quality.
georgetroy
>I would agree with the others the Jet 1642 is a better choice for a lathe that will fit your needs for now. In my opinion Grizzly makes better bandsaws than lathes. I have turned on a couple Grizzly lathes not a good experience. If you are going Jet and don't get the 1642 you will regret it later. GT
Re: Shopping for new lathe *LINK*
Kurt Rosenzweig
>Gizzly is coming out with a 1640 clone next month and a pretty fair price! Might be worth a look see.
http://www.grizzly.com/products/G0632
MIke from St. Clair Shores
>Dominic Greco did a great review on the 1642 here on WC.
I put the link below.
Good Luck,
Mike
Dominic Greco's 1642 lathe
Ray Binnicker
>Thanks folks ! I knew I could depend on you. I'll do a little more thinking, but I believe the Jet is back on the top of the list.
Oh, I said "electronic" speed control; I really meant anything other than having to, loosen the motor, move the belt on the pulley, tighten the motor, etc. (:-)
Peter Hyde
>Ray,
I think maybe it might be cheaper to do an electronic variable speed upgrade on your existing old Delta. Unless you are looking for an increase in swing as well, there is a lot to be said for hanging on to old iron. Lots of accessories and some good USA engineering. I'm very happy with mine.
Russ Fairfield
>If you want a recommendation for the 14: Jet, you just got it. I have become a fan of the 14" Jet since I started using one of them for classes at the Woodcraft store a year ago. I have subsequently purchased on of them for my shop.
The 14" Jet is now selling for $900 at Woodcraft, and that has to be the most lathe for the money on the market. It does have a mechanical drive, but it it is a good one that will do everything the 16" lathe will do except run backwards and turn a 16" piece of wood. Personally, I can't see those being worth another $1000.
On the down side, some folks have criticized the location of the motor. I have been using one of them at the Woodcraft Store and in my shop for the past year and it has never been a problem. I do find the speed selection handle on the front of the headstock to be in the way at times when I am using the top speeds, but that is only an annoyance that takes some getting used to. It is not something that interferes with using the lathe.
Keith Tompkins
keith tompkins
>Ahhhhhh....thanks, Peter. I love old woodworking equipment. That was a major factor when I bought my General. It LOOKS like a lathe should look, and FEELS like an old iron lathe. If I could afford it, I'd start a lathe museum.
Rick Davenport
>I own a Grizzly band saw and Grizzly drill press and I'm perfectly happy with them.
Good products for the price.
I would hesitate to go with a Grizzly lathe though.
A friend bought one (I don't remember the model) and had a hard time getting the head and tail stocks to stay lined up.
When I took Woodturning 101 at Woodcraft, my teacher told me that if you are really hooked on turning, then buy the best lathe you can afford. It's all the other stuff that will add up to more money than the cost of a good lathe.
R
Re: Shopping for new lathe - outboard turning?
BTF
>Does anyone have pictures or details on how to set up for outboard turning on a Jet 1642? Attachments needed, purchased or made?
Look at Nova 1624-44
Gordon Seto
>I think the new Nova 1624-44 is also worth considering. Now they are on sale at Woodcraft for $1K with a free G3 ($150 value) chuck. For $850, it is not bad for the money. Both Nova & Woodcraft have excellent service.
Gordon
>Outboard turning on a Jet 1642 an interesting propostion. You basically have to slide the headstock to the end and have a freestanding tool rest. Of course if you do this, you have to counterbalance the headstock weight - otherwise it can vibrate a bit much. Of course if your lathe is bolted to the floor, it's not a problem.
Re: Look at Nova 1624-44
Jim Swank
>This "new" Nova looks a lot like my later model Nova 3000. It should be a pretty good lathe if you don't mind changing belts to change speeds. And at the sale price with the chuck thrown in a real bargain that will do more than 16" with the swivel head.
John Jepsen
>If you're considering a Nova, and can afford it take a long look at the Nova DVR XP. I just bought mine and fell in love instantly. I have never used such a quiet and smooth tool. Yeah, it will cost 2G's but you won't be bothered belts, noise, vibrations etc. I waited along time and looked at many different lathes, the Nova DVR XP was worth the wait.
Neal_Addy
>Ray, I've been driving the 1442 for a year and couldn't be happier. It's a quality piece of turning beauty. I figure it will serve me well for quite a few years (until the call of that 3520 gets too strong to resist).
That said, I'd agree that the 1624 should be at least considered. It has a few bells-and-whistles that you won't get on the 1442 (reverse, digital, EVS, etc). You'd have to decide if these are important to you.
I don't think you can go wrong with either. Both great lathes.
Re: outboard turning?
Karl in IA
>I believe a while ago, there was a piece on the AAW forum with photos, showing attachment of a Vicmarc outboard turning accessory on a Jet 1642.
Jim Swank
>The DVR XP is a bit beyond his stated price range. No doubt it is a sweet lathe, and it does address the tailstock deficiencies on the Nova 3000 (the 1624 appears to have the same tailstock). But for another $500 you can get a Powermatic 3520, which I'd prefer were it my money.
Gordon Seto
>The 1624-44 has the same tailstock as DVR XP; definitely not the light duty tailstock that 3000 had.
Gordon
Ed Wujciak
>After turning for 2+ years on an antique (50 plus yrs old) Shopsmith 10ER, I decided to take the plunge and bought the Nova 1624-44 from the local Woodcraft. They set it on the floor in the morning, I took it away in the afternoon. Since the Shopsmith is all I've ever turned on, I certainly don't have any perspective on REAL lathes, but I'M IN HEAVEN!!!!! Plus, I can use the Shopsmith for other things again.
