Re: Spraysystem for finishes *LINK*
nailshooter
>I have to say, I am a little more than dumbfounded at reading not to use HVLP with solvent finishes. What about the thousands of us that do? I have used the Apollo, Graco and Turbinaire systems before, ALL with solvent based finishes - no latex.
But I have found that my Fuji pro (highest volume turbine out there) is the best system I have ever used, and it was recommended to me by some of the best finishers locally as well as on the net. I have used it for over a year, and it has paid for itself many times in the work I have done in restoration at a local historical building where overspray cannot be tolerated. The money is saved on material savings as well as the lack of cleanup and prep due to less overspray. I finish/refinish doors, tables, wood paneling, etc. all the time and no other system goes to the job with me.
BTW, if you are interested, I shoot >super high< VOC conversion lacquers as well as low solid high flash industrial enamels. And I do that in humid South Texas heat; I don't shut down because it is summer. You do have to learn to proper thinning, pressure requirements, etc. for your gun and your material, but once you have that down you are good to go and can spray with wild abandon. My only limitation is in the summer, when I have found that I cannot spray outside with my conversion materials when it is over 100 degrees. But I can still spray commercial grade polyurethanes - even in the heat.
Go by any professional (not HD) finisher's supply house and ask them about shooting solvent based through HVLP compared to latex.
You will be surprised... none of us in my area use latex in our machines. None of us want any kind of water or residue in the guns, packings, seals or workings. We all keep cheap conversion guns around for latex. For me, I have a small airless that has a finish tip and a broad tip, and it is for latex only.
My system cost about $1600 and could be had for a LOT less by someone that doesn't need all the different tips, hose extensions, filters, etc. that I use.
I am thinking that your experience might be with one of those $100 machines. Although, some have reported good luck with those.
If OP is still following this, I would look at this gun at the link below. I have it and use it a lot, and it shoots as well (sadly) as a $250 SATA gun. I use mine a lot when I have a small job as I can just pull air off a job compressor or one in my shop. Out of this gun I have shot water based, and mineral solvent based as well as high VOC. If the link doesn't work, try the harborfreight site, item #90977. It even comes with its own regulator on the handle. It is really easy to clean, too. It is not true HVLP, but a conversion gun which is almost as good.
I will never go back to high pressure guns (and in many states like CA professionals cannot use them) even though I like them. I learned on them, and I can set the gun up while asleep, but that was yesterday's technology. The is a learning curve when starting with HVLP, but the rewards are plenty.
Robert
http://tinyurl.com/y24n6g
