Reversing a lathe
Reversing a lathe
Reversing a lathe
David Walser
>I have a woodfast lathe with a 2hp 220v motor. One thing it lacks is a switch to reverse the direction of the lathe. Can anyone point me to directions on how I could install such a switch on my lathe?
Re: Reversing a lathe
Russ Babbitt
>More information needed....is the motor AC or DC. If you are saying it is 220v it is AC. My old Woodfast 220vac input to the converter to a 180vdc motor. I do not believe that AC can be reversed.....without rewiring the motor.
David Walser
>The motor is 220v, single phase, AC.
Danny Wells
>Dave,
Can't be done on AC unless you go to an inverter that converts the power to 3 phase and use a 3 phase motor. Then you can go variable speed and reverse. It is well worth it. If you want to know more, let me know and I'll e-mail you an article on how I converted my Jet mini to a 1HP 3 phase with variable speed and reverse long before Jet even thought about it.
Danny
David Walser
>Danny,
Thanks for the offer. I'd appreciate a copy of the article. Just FYI, the lathe already is set up for variable speed. (It has a variable speed controller, along with a five step pulley. The only thing it doesn't have is a switch to reverse the lathe's direction.)
Jim Swank
>Ummm, not exactly, as the commercial says. You can reverse the start winding on a single phase AC motor if the leads are brought out separately, and most are.
Chuck Engstrom
>Some motors can be reversed by rearranging the wiring inside the motor. Instructions are usually given in a diagram on the motor ID plate or inside the plate that covers the wiring connections. With the proper switch and wires, you can move this arrangement outside the motor. Be sure to unplug the motor before you start poking around the wires, and get some help if you're not sure what you're seeing inside there.
Best--
Chuck Engstrom
Jim Swank
>If it has a variable speed controller, then the motor is either AC or DC.
If it's DC, you can reverse the armature leads and make it run backwards. You can do the same by reversing the field if it is a wound field, but many motors these days use permanent magnet fields, which cannot be reversed.
If it is an AC motor, it should be 3 phase. In that case, you can "simply" swap 2 phases and it will run backwards.
Given the discussion to this point, find someone who is an experienced industrial eletrician and get him to look at it. Even though the process is fairly simple, it's easy to damage equipment or bodies if you don't know what you are doing.
Re: Reversing a lathe *LINK*
David
>My former lathe, a Nova 3000, had an external controller which was mounted to the wall behind the lathe. It had a reversing switch. The motor was a 1-1/2 hp Leeson, 220 V single phase. The controller was from KB Electronics. You may find a match for your motor here.
KB Electronics site
Roger
>Chuck is right. I did it on my old Craftsman lathe, with a single phase 110 volt motor. Checked the schematic under the cover plate, found the right wires, routed them to a 2-way switch, works fine.
>I would look at the wiring diagram inside the motors wring box. If it shows how to run it clockwise and counter clockwise then it can be reversed. Its a matter of "reversing" two wires. That is, moving wire A from terminal A to Terminal B and wire B to terminal A.
A double pole double throw (DPDT) switch (I think) will do the same thing. So you would need to find or make a place to mount one. This might require adding some wiring or adding a ring or extender tot he box on the motor. But its atually pretty smple once you figure it out. The switch must be for the amperage of or greater than the motor.
When I was a kid about fifteen years old, I bought a Craftsman lathe and motor. (120v 3/4hp) A friend showed me how to wire the motor termanals to a two prone recepticle and a chord with a two prong plug to the leads. When you wanted to reverse it, you just pulled out the plug and twisted the wire and inserted it with the prongs reversed. Used it off and on for forty years and sold the lathe. Was removing the homemade reverser but the buyer liked it and kept it.
Nancy Jubb/ Eddie Pacheco, In Denver
>Hello, David. Here's a link to "Happy Woodworking" that has a fine diagram of how to wire in a reversing switch for an AC motor. I hope this works for you.
http://home.earthlink.net/~mgoodall/happywoodworking/MotorWiring.html
dwr
>David,
AC can be reversed. I have done it on my lathe, although it is not a VFD set up.
I installed a Drum Switch and had the 110v motor wired to the switch. I now have FWD and REV throws and the middle detent is Stop. New ones can get spendy but they are on Ebay all the time. Here is a link to one just like mine, with about 3 days to go, it is $22 plus shipping.
Many Variable Frequency Drives (AC Motors) have a REV option that can be installed on the drive, however, not ALL VFD model numbers will support this feature. Check with your manufacturer to see if it is available for your model and what the cost is. Also check to see if there is any "special" considerations you need to make inside your VFD (program settings, fuses, etc.)
If you go the Drum Switch route, make sure you consult with a qualified electrician on how to install the switch in conjunction with your VFD unit.
Good luck...
Ebay Drum Switch
