Peppermill save needed!
Steven Antonucci
steve antonucci
>I have a 10" peppermill kit and my blank finished out at 9 7/8" or so. Have any of you ever cut the rod down and tried to thread it?
Or would I be smart just to cut in an band for the middle and laminate it in place?
I could also turn a small spacer and glue it in at the bottom to make up the difference? I already have a piece of ebony that volunteered...
Which would you do (any which is/are foolhardy?)
In the grand scheme of things, I'd rather have the entire mill appear to be solid cherry, but any port in a storm...
Steve
Re: Peppermill save needed!
Dominic Greco in Richboro PA
>Steve,
Is this kit the type that has a square rod with a small portion threaded at the end? If so, that's the kit I've worked with.
In the past when I've made a similar mistake, I've cut a small disk of contrasting wood out, drilled a 1" diam hole in it, flattened both faces and sanded it smooth, then glued it to the top of the base. On the kits I've built, this portion has the 1" diameter hole in it. Use you lathe as a press, and your live center to help "center" the inlay disk. Be sure to make the inlay disk larger in diameter than the base. That way you can cut it down to the perfect size.
The lady who purchased the pepper mill featuring this fix remarked that this "design feature" was what caught her eye. Can you believe that? :>)
Good luck.
See ya around,
Dominic
DD
>The kits I have used have a square end at the top and a threaded portion at the bottom of the rod. I have simply cut off the square end of the rod to fit the peppermill and punched the new square end with a nail punch to splay it so that it does not pass through the head of the pepper mill. You could probably also simply hammer the square end to splay it as well.
Cheers.
Doug
Mike Cunningham (Cape May NJ)
>Steve,
I make and sell dozens of mills yearly, I use the stainless steel kit that CS bills as the Deluxe kit, I buy them from Chef Supplies. I'm assuming that's the one that you're using.
Several years ago I stopped buying multiple sizes, I buy them in 24" and 14" and cut them to fit. Simply place the rod in a vise and hacksaw off the amount required, then peen the end.
Mike
stacey s
>Also if you have the ability to cut threads you can cut off some of the thread and then extend the thread further down. I found that I can just continue on down threading the square rod without much trouble. I acutally found this simpler for me. I had difficulty flaring the square end back out.
Stacey
>Stacey,
After cutting the end, gently pean with light taps of your hammer. Tap the edge from the end toward the vise hitting the edge of the end on all four sides on an angle, you just need to create a very slight flare (almost like a burr) so that the rod is captured in the grinding mechanism. Very quick and easy.
Mike
MIke from St. Clair Shores
>Steve,
You can simply grind off some of the thread with a disc sander, it sounds like you are only off 1/8 of an inch.
Good luck,
Mike
Bill Deak
>The rod is aluminum. I simply cut a small amount off the end with a hacksaw and stand it up in a vise with the cut end about 1/4 inch sticking up and gently peen the end with a hammer. It looks the same as the factory end.
Phil Axtell
>Hi Steve,
You could also drill the recess in the bottom (1 5/8" I think) 1/8" deeper and thus raise the rod up. Just another idea that might be easier.
Good Luck,
Phil in Balmy Central Florida
Steven Antonucci
More info...
steve antonucci
>The center rod is square, but threaded on both ends. The rod is too long in the squared section, so I don't think cutting it will help. It threads into the grinding mechanism and the little nut at the top with both pieces butting against the squared section.
Last night, I glued in a small section of ebony down by the grinding mechanism, and it is within 1/8" of being perfect. If the rod is aluminum, I'll file it and tap it to finish off the last 1/8".
Thanks for all of the suggestions.
Steve
