simple 1/2" chuck question
Gary B. in Central NY
>Ok, so I got a present from Lee Valley today for my lathe, a 1/2" drill chuck with morse taper adapter. Now, I noticed in the Catalog, it says " Drilled and Tapped for a 1/4x 20 restraining rod, not included" Is this something I need?!? what is it? it seems that the chuck is tapered to fit the adapter ok, but I'd rather be safe than sorry......Thanks for the heads up
Gary
Re: simple 1/2" chuck question
Randy Rhine
>Hi,
Yup...it's something you need. Even with the morse taper, it will sometimes work it's way loose. So...just get a length of threaded rod long enough to fit through your headstock. Then make a knob(I just used a threaded insert in a piece of plywood). I think the techy term for this is a "drawbolt".
rr
david
>I'm by no means the expert here, but I have used a chuck with morse taper in both headstock and tailstock applications, and have never had to be concerned about restraining devices attached to it. The only problem I have encountered is when lubricant gets on any of the mating surfaces, when a slippage could occur. Clean the surfaces dry, and everything works like they should.
>Depends on how you use it. To drill holes you don't need the rod but if you use it as a chuck to turn things or to buff items then a draw bar is really useful. The vibration from turning and buffing will work the morse taper loose. Usually it just comes loose and stops but you risk damageing the project and possibly the morse taper. better be safe than sorry.
>I see....I was talking about the adaptor to the chuck though, not the adapter to the lathe.....I think I'll try it without, if it slips, then I'll rig up that drawbar thing. Thanks, that's what I love about this website. Quick, knowledgable answers.
Russ Babbitt
>The drawbar is cheap insurance whether you are drilling or holding a piece for turning. Why not make one and use it just to be safe. If it ever did come loose it could damage you, your work piece or the lathe.
Bill Howatt
>If I understand this post correctly, you have yet to mate the chuck to the shaft which will have the Morse Taper on one end and a steeper taper usually called JTx on the end which goes into the chuck body. (I wonder if JT stands for Jacobs Taper???) The threaded portion for the drawbar has nothing to do with holding the chuck onto the shaft, only for pulling it into the lathe headstock.
I always use the drawbar as John Lucas says it depends on what you are doing and if the operation does not cause pressure to force the chuck into the headstock (like drilling) it will work loose. I have personal experience with that!
Bill
Pete LaBelle
>Gary -
I've seen retaining screws inside of chucks to hold them on to the morse stub before. Chucks typically have a "Jacobs" taper in them. Make sure both surfaces are clean and drive them together. I will warm my chucks in an oven to about 250 degrees F, then drive them together. The chuck will shrink even tighter onto the stub. You shouldn't have problems afterwards.
Pete
