REAL MILK PAINT
Maple Hollow Form (PICS)
Mike Rubes, Apex, NC
>Hi all,
This is a maple hollow form with rosewood collar. This one was very fun for me because it was my first hollow form that I've taken straight from the tree to finished product! I've turned a few from dried timber, but never from wet. I roughed it back in April or so, alcohol soaked it and set it on the shelf. About 2 weeks ago, I mounted it up and finished it. The maple was a little soft, but still turned nicely. I like the one line of ambrosia across the top.
It is about 7 inches across and 4 high. I left it pretty thick as again it felt soft and sounded thin to me. It is about 1/4 inch thick, maybe a bit less at the rim. Finish is Tried and True and then buffed. It's a Christmas gift and is already wrapped and under the tree!
I think the form is ok. My pictures need work, for sure. The bottom could be a little smaller I think and maybe a bit more "lift" along the bottom edge? Comments and critiques are always welcome.
Thanks for taking a look,
Mike
Cleaned enough to see the shop floor in Apex, NC!!
Re: Maple Hollow Form (PICS)
David Breth
>Mike -
That is very nice. I like the ambrosia too - looks almost like a belt!
David B.
Brad Vietje
Nice ! I like the racing stripe...
Brad Vietje
Nitpicking here...
david
>I like this piece, Mike. Since you asked for comments, here goes: I would have continued the curve to die on the bottom with a smaller diameter rather that have a bit of a foot. Keep in mind that I prefer not to have a foot in all my pieces. The curve sort of flattens out just below the widest point. This is both a plus and a minus. On the plus, it makes for a more distinctive piece. On the minus, I believe continuing the curve would have made a more "uniform" shape. Just my two pennies worth.
Brad Vietje
Tried & True question
Brad Vietje
>I've been using T&T Original for a month or so when I wanted a low sheen finish... I might want to buff a few of them. How long did you wait before buffing ?
Safe spinning,
Brad Vietje
Newbury, VT
Re: Nitpicking here...
RevDoug
>David, I was thinking the same thing, that the curve seems to flatten out. But a pretty nice piece altogether.
>Hi David,
Thanks for your note and suggestion. It's funny, but I never even considered *not* putting a foot on it, but as soon as I read your post, I could see what you were saying and I agree. I think the foot is ok, and I do like the way it "lifts" the piece, but it is a little abrupt and tends to draw your eye (at least mine) to it. I think a smooth transition on the bottom with no foot would have indeed been better. Good suggestion.
I struggled getting the right slope/shape to the underside of the body and I think it is because the curve should have naturally continued on, but I was stuck in "foot mode" and tried to force it a bit. The beauty is I have a lot more of this maple so think I'll give another one a spin during my week off at Christmas!
And I would never think a good, constructive critique was "nitpicking" :)
I hope all is well in Hawaii,
Mike
There's always a bowl waiting in Apex, NC!
Re: Tried & True question
>Hi Brad,
It varies quite a bit depending on my available shop time, but I've applied the T&T varnish with a paper towel and then rubbed it with a dry towel (while still spinning) and buffed it with the Bealle system 30 minutes later. Or, I've waited a week until I could get back into the shop! I've not noticed any difference in how the final finish looks. The T&T seems to dry pretty quickly. I keep mine in a ketchup squeeze bottle (new one, never had ketchup in it!!!) and that way can just squeeze out a drop or two at a time onto a papertowel and use that to apply a little bit at a time.
Good luck!
Mike
Might even (GASP!!) drop below freezing tonight in Apex, NC!!!
