elm vessel
elm vessel
elm vessel
>Here is the finished elm vessel with the new finial. It has gold beads inside the finial. I textured the top where there was a bleached out area.
Re: elm vessel
finial detail
>Here's the finial I finally came up with . It is holly dyed black and lacquered. I didn't like the gloss because it looked like plastic so I knocked it down with steel wool and brought it back up slightly with Johnsons paste wax. I hammered some brass wire to form an enlarged area and inserted it in the beads. I'm pretty happy with it except for the cove seperating the ball from the bottom. For some reason it just doesn't look quite right. I think perhaps it should have been a little smaller.
Re: elm vessel
Re: finial detail
Tom Libby
>Nice! I think elm is underrated. The beauty of its grain in is the fine details.
Re: elm vessel
Re: elm vessel
David
>John, I realize that your intention was to turn a defect into a design feature, but to me the texturing feels like it shoud continue down the lower half of the curve, perhaps to the left to sort of balance out the top. In for a penny and all that...
Re: elm vessel
Re: elm vessel
>David I thought about that and started to do it one are. The change in contast really shows up in the texture so I stopped before I ruined it. If I was making the piece from scratch with a good piece of wood I would probably do lots of things differently.
Re: elm vessel
Re: finial detail
Allen Neighbors
>John, I love this piece... Finial, too. The texturing reminds me of some of the china berry I've turned that the worms literally textured for me. :o)
The finial is awesome! Did you just turn a funnel, and then carve it to it's final shape?
Re: elm vessel
Or, maybe eliminate the cove altogether?
Barry Turner
Re: elm vessel
Re: finial detail
Mike Cunningham (Cape May NJ)
>I like it, perhaps the cove should be a bit narrower. I can't tell in the photos, are there small details/steps at the top and bottom of the cove setting it off from the remainder of the finial? Perhaps it needs those in addition to be a bit narrower....
Mike
Re: elm vessel
Re: finial detail
Jim
>Thanks for posting this picture John. You just gave me an idea I've been needing to rescue a box that had a "design opportunity".
I like the whole thing John. Maybe it's not perfect, but then I'm not sure what turning is ever perfect - I'm sure not there yet!
The totality of the piece is easy on the eyes. Very pleasing.
Re: elm vessel
Re: finial detail
>Allen that is what I did. I turned a funnel then drilled down through the bottom so I had a place to run the "stems" for the beads. Then I slice it with a coping saw and carved away the rest with a dremel.
Re: elm vessel
Re: Thanks, John
Allen Neighbors
